Rear door creaks loudly when opened
This started a couple of months ago. When you open the rear door, one of the struts sounds like its stuck, and creaks loudly as its opened. It almost sounds like the door is sticking closed.
Anyone else have this issue? Car is going in this week for the recall, so Ill have them look at this as well.
Nothing has happened to the car that would have caused them to get damaged. No accidents, the door hasn't been opened into anything, no weight has been put on the door. It started happening out of the blue...
I would suggest having the dealer look at it under warranty, especially if you have the power rear door option and it has something to do with the lifting mechanism.
Does it only make the noise opening?
There you go! Publish the TSB number please.
Or if you had extended warranty, this would have been qualified.
Any mechanical problems, will be covered by the Lexus Extended warranty (related to operation of key mechanisms).
EL013-07
2004–2006 LEXUS RX 330, 2006–2007 RX 400h, 2007–2008 RX 350; POWER BACK DOOR NOISE
Some customers may experience a condition where the power back door will make a “popping” or “creaking” noise from the power back door drive unit.
I found this at: http://forums.theautomedia.com/local...=47&linkid=416
EL013-07
This is the second instance where I've taken the car in and had them give me the run around. Last time I said to the service manager, am I going to need to argue with you every time I bring the car in for service?
Apparently the answer is yes.
^I feel for you. You know there is a problem and they (the dealer) knows you wouldn't be there if everything was ok, yet they tell you all is well and the problem muxt not exist.
