RX400h
I have 2006 RX400h with over 93k miles on it. I remember when I first purchased, it used to get 27 - 29 mpg. But now it only gets 23-24 mpg. (Not to mention that my driving habit never changed..) It seems #mpg goes down as the hybrid battery gets older.
Does anybody who owns 400h have same experience ?
Have you ever replaced the 12 volt battery under the hood? Or had it run down so it needed a boost?
If you have, you may need to do the ISC learning procedure. Look here...
http://us.lexusownersclub.com/forums...howtopic=58929
If you're not comfortable doing it yourself, take the TSB to the dealer and ask them to check to see if the ISC learning procedure is complete (they can hook it up to their computer to confirm this)
If you are comfortable doing it yourself (I have done it many times) see here
http://us.lexusownersclub.com/forums...howtopic=58930
Don't forget as well if you live in a cold climate, that winter gas will negatively affect your mileage, as will driving in the colder weather - the ICE must run more often to provide cabin heat and keep the cats at proper operating temperature.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
rcy,
Thanks for a valuable info. I have tried by my own and it worked. Now I am getting 15% better mpg. Yes, I did replaced 12v battery because it died. The battery was only 3 years old and I think it is supposed to last much longer than that. But anyway I am happy now for the better mpg.
rcy,
xRYD3Rx
05-20-13 03:28 PM
glassmanj
Hybrid Technology
08-08-12 11:43 AM
