Headlight Washers Stuck Open
Old 01-06-10, 06:59 AM
mws4ua
mws4ua's Avatar
Default Headlight Washers Stuck Open
I searched but saw nothing...
It's been FREAKISHLY cold down here the last couple of mornings, and our cars are parked in a car port w/o heat. Yesterday and today my wife's '06 RX 330's headlight washers have been stuck open. Yesterday it was about 1.5", today about 0.5".
I tried pushing them down gently, but didn't want to force them. Yesterday they were still up when my wife got to work, but were back in place by the time she left. I bet the same will happen today.
I suspect that the fluid in the lines is freezing, which causes it to expand and push the washers up, but I wanted to check with y'all to see if there's another potential (even non-cold-related) reason for this.
Thanks!
Old 01-06-10, 07:08 AM
lexus114
lexus114's Avatar
I never used mine,do they even do anything? But to answer your question,I think you nailed it: "I suspect that the fluid in the lines is freezing, which causes it to expand and push the washers up".
Or,it`s malfunctioning.
Old 01-06-10, 09:35 AM
mws4ua
mws4ua's Avatar
Originally Posted by lexus114
I think you nailed it... Or,it's malfunctioning.
Ha... thanks.
We don't use them much... I doubt they do much good when we do. They just look ugly when they're popped up like that.
Anybody else?
Old 01-06-10, 09:49 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Not sure what's going on but I'd recommend not using the windshield washers when the headlights are on so the little headlight washers don't pop up. Or you can turn the headlights off and use the windshield wash.
Old 01-06-10, 09:58 PM
mmlex1987
mmlex1987's Avatar
My headlamp washers have a completely separate button to activate, not the windshield washer lever. I thought they were all like that. It is a button just to the right of the heated seat ***** if the vehicle is equiped.
As for the headlamp washers stuck out, I am not sure I have ever heard of the problem. But then again, nothing I hear surprizes me anymore!
Old 01-07-10, 03:22 AM
kitlz
kitlz's Avatar
I have the separate button by the shifter too. The headlight washers are activated when the headlights are on and the windshield wash is selected.
Old 01-07-10, 07:44 AM
mmlex1987
mmlex1987's Avatar
Anita,
so are you saying they work both ways?
1.with their own switch & 2. with the main windshield washers level? I did not know that, I thought they only operated with their own independent switch.
Old 01-07-10, 09:13 AM
kitlz
kitlz's Avatar
Originally Posted by Mike DeAno
Anita,
Mike,
Yes, the headlight washers should work both ways - using the switch by the shifter or through the windshield wash but only if the headlights are on.
Anita
Old 01-07-10, 05:14 PM
Arbitrage1
Arbitrage1's Avatar
Ours work both ways as well. If you have the lights on and wash the windshield, the headlight washers activate at the same time.
Old 01-07-10, 09:55 PM
voodoojc
voodoojc's Avatar
Mine did the exact same thing.. they're back to closed now though.
Old 01-07-10, 10:01 PM
jgr7
jgr7's Avatar
The headlight washers work both ways but not every time you use the windshield washers, it seems to me I read that is is only the first time and every 5th or so time after that when on the same trip and the headlights are on. You should get some of the washer fluid that is good to -32F for the winter time. I had my wipers freeze to the windshield while driving over Donner summit on my old RX300 when i didn't have the -32 washer fluid in the washer tank.
Jeff
Old 01-07-10, 10:10 PM
mmlex1987
mmlex1987's Avatar
Jeff
It goes to show that we can learn something new everyday! Thanks.
Old 01-08-10, 10:30 AM
RXSF
RXSF's Avatar
Either way, the button behind the shifter and the windshield washer ONLY work when the headlights are on. Even the dedicated button doesnt work if the headlights are not on.
Im not sure if it is related to the 5th time you use the windshield washer when the headlights are on. I was under the impression that it will always wash the headlights if the headlights are on and you activate it through the windshield washer, that is unless you just did it.
Old 11-28-16, 01:36 PM
tzw
tzw's Avatar
Default replacing headlight washer cover
Hi everyone
I have rx 300 05 and one of my headlight washer cover went missing. So I bought the replacement from ebay and I got it with me. However I have no idea I can I fit new part in to my car. If anyone ever experienced replacing headlight washer cover please check my pics and tell me what am I missing. Thank you This is what I bought from ebay
This is my car
Old 11-28-16, 02:10 PM
jenright
jenright's Avatar
Mine started acting erratically on the 2005RX. Completely random, or so it seemed.
It's a dedicated fuse. Pulled the fuse. Problem gone. Nothing else affected.
They don't do much so no great loss.
crocs430
02-05-19 03:54 PM
Cruf665
03-29-18 01:12 PM
tbilisi79
01-05-16 10:36 AM
ferg5162
09-03-08 12:12 AM
Quick Reply: Headlight Washers Stuck Open
