Adaptable headlight sensor
My boss has a problem with her 2nd gen RX400h, the adaptabble headlight sensor went bad. Local dealers gave her 700-900 estimates
Is there a cheaper solution with this, how much does this sensor cost by itself, and is there an aftermarket sensor out there?
sounds rare to me,
that part would only be available through the dealer ONLY.
so the only way to make it cheaper is on the labour side. take it to a cheaper shop, or better yet, do it yourself.
when you buy the sensor, the parts catalog will show where it goes,
hope for the best i guess
Are they talking about the sensor connected to the rear axle/suspension? That think looks like it should cost about $40. Looks like it anyway. Have a look on the passenger side of the rear toward the middle of the car from the muffler. You'll see a plastic case with an electrical connector and a metal rod connected to the suspension pieces. The sensor I'm talking about is used for headlight levelling, not the headlight swivelling (I think).
Look here http://us.lexusownersclub.com/forums...howtopic=41386
Is this the part they are talking about? Looks like someone had it done at the dealer for about $400.
lostape45
04-02-15 12:25 PM
