Rear quarter window exterior molding fell off RX330
#166
here are your choices you can go to the dealer pay $184.00 for the whole window because you cant buy the trim separate from the dealer plus $125,00 to install or you can buy just the window with the trim for $120.00 on e bay but have to get it installed at a window shop for around $80.00 this is the only other option to solve your problem
There is an alternative you can buy the separate trim piece on amazon or e bay
Here is the link to the instructional video that show how to install it hope this helps
#167
found a replacement trim on amazon and e bay for cheap
Its about time!!!! a replacement trim that can be installed on the existing window saving you time and a lot of money, I went to the dealership they wanted $186.30 for the whole window plus $125.00 in Labor to install it because they send it out to a glass shop add the with tax its way over
$300 bucks, I found these on e bay and installed them on my RX went on easy after following the instruction video
there is a video on YOU TUBE showing how it is installed
here is the link
here is the link
#170
2004 RX 330 Rear window trim
I have a 2004 Lexus RX 330 with 144,000 miles on it I was driving home last night on the highway in my rear passenger side window trim came loose. I read your thread that you reinstalled yours using silicone can you tell me if it’s still holding up today.
Thank you,
Thank you,
#172
2004 RX 330 rear window trim
#173
These moldings are badly designed - rear doors impact them while opening, and "unmount" them as a result.
My right molding has broken while driving on a highway, so I unmount the left one due to not lose it also ($80 at eBay is too expensive for a piece of plastic).
#174
Like I said, my passenger side rear window trim came loose yesterday while I was on the highway. I took it completely off once I got home. Today I went to a local car window repair company called Glass America. The manager looked at the trim and said he can epoxy it back on. I’m scheduled to take my 2004 RX 330 in this Saturday. In the meantime, I noticed my driver side rear trim was loose as well. So, I took that trim completely off. The hard work is in the preparation. Getting all the old tape off and cleaning the surfaces. I will post before and after pictures and the total cost.
#175
#176
I took my 2004 Lexus RX 330 to Glass America today and the manager put a bead of Urethane on both rear window trim. For $40 the problem was solved and I saved $700.
#178
TCB
#179
Our is also still holding up well.
