Any high mileage RX without transmission problem?
Old 02-01-14, 04:26 PM
  #136
mpatton
mpatton's Avatar
Originally Posted by RX330inFL
It makes it better. Will not say it completely solves the problem.
Thanks. Hell, I'm just elated to have received the headlight condensation letter (and thankful I didn't try to seal it myself like I was going to a few weeks ago!)
Old 02-01-14, 07:21 PM
  #137
lex_rx
lex_rx's Avatar
242K kilometers and no issues other than the usual hesitation. Gotta be firm on the gas between that 2nd and 3rd.
Old 02-01-14, 10:54 PM
  #138
OceanView
OceanView's Avatar
Which year is your RX?
Old 02-02-14, 04:58 AM
  #139
lex_rx
lex_rx's Avatar
2004 sport made by my fellow ontarians. Added to my sig now and a rare pic in the RX's now-completed new garage/home.
Old 02-03-14, 07:37 AM
  #140
mpatton
mpatton's Avatar
Yeah, I find if I am consistent on the gas between the gears, I rarely have an issue. It's a little unsettling though to go around a corner in rush hour traffic heading onto the interstate and let off the gas due to traffic ahead of me - only to have the car go CHUNK in the shift. Ugh.
Old 02-20-14, 04:54 PM
  #141
marilyn43
marilyn43's Avatar
Default any out there have an 1999-2003 rx 300 and gotten a new transmission
I have a 2001 RX 300 with 114,000 and the transmission died- I am spendingn $3100 to have it fixed and it comes with a 3 year/50000 warranty- Anyone had their tranny rebuilt and not had problems? Hoping this is the right call!
Old 02-20-14, 06:15 PM
  #142
Rainbird
Rainbird's Avatar
Welcome to Club Lexus Marilyn43. The car is worth about $6000. This is a tough call and depending on the quality of work for the rebuilt transmission it could go either way. I guess it comes down to what you can afford. With that age and mileage I would personally junk the car and buy a RX330 with less mileage. I really hope everything works out with this new transmission. Let us know how this turns out.
Old 02-21-14, 02:18 PM
  #143
ecrane
ecrane's Avatar
2001 RX300 with 168,000 miles. We bought the car in 2003 with 16,000 miles on it We passed this on to our daughter when my wife got a 2007 RX350 back in 2009. Recently started making some ominous noises, per our daughter. She had it to a independent Lexus/Toyota shop but didn't get a full diagnosis other than, yep, that could be the transmission. She decided to trade it in on a 2012 Highlander Limited 4WD. My daughter did have the trans fluid exchanged @ 120,000 miles by the shop mentioned previously. The fluid exchange was the one and only transmission service this vehicle had. Got $4000 for the RX on the trade.
Not sure if trans was failing, but I think 168,000 miles isn't bad. BTW, late model Highlander Limited's are very nice vehicles.
Old 02-21-14, 04:01 PM
  #144
jbl-1985
jbl-1985's Avatar
Agreed...my brother in law just got a new Highlander Limited and they are VERY nice - the line is starting to get a little more blurred between the higher end Toyota's and their Lexus counterparts.
Old 03-21-14, 07:44 AM
  #145
stillbill
stillbill's Avatar
My wife's 2002 RX300 (bought new in 2002) has 240,000 miles (386,242 km) on the original tranny. Early this morning when I walked her out to her car as she left for work I heard a whining sound that was loudest from under the car. So 240,000 miles may be about all we get:-) Her car has been really trouble free - biggest deal was normal replacement of the timing belt - lucky I guess.
Old 03-21-14, 07:48 AM
  #146
jbl-1985
jbl-1985's Avatar
Not saying you do NOT have a trans problem, but a loud whining from under the hood could be other things too...alternator, power steering pump possibly.
Old 03-22-14, 02:53 AM
  #147
Gordonrx
Gordonrx's Avatar
2005 Thundercloud 88,000 AWD. Do not like the shifting. It doesn't downshift all the time when I step on it. Most times (80%) I have hesitation when trying to pass. It shifts too smooth, no power torque when shifting.
Old 03-24-14, 01:33 PM
  #148
stillbill
stillbill's Avatar
Thumbs up Is a Transmission Flush worth the cost? Or just drain and refill?
Thanks JBL - the way my luck has been lately, well, lets just say it wouldn't surprise me if it was the tranny. You know - "if I didn't have bad luck I wouldn't have any luck at all". I'm covering the basis. As a by-the-way, it seems a transmission flush is strongly suggested by some knowledgeable sounding folks - and that there's a machine that can perform that chore? Draining and refilling I could manage, but not a flush. Any suggestions? Is it a worthwhile preventative measure?
So, when my wife came home, the whining noise was hard to hear, if at all. No noise when the steering wheel turned, no change in pitch when shifting between gears, no difference with HVAC on or off. Hmm, I said... and checked the oil which was a full quart low. Maybe it was a cold engine whining that it was a tad low on oil. We'll see, but for now, she seems okay.
Old 03-24-14, 01:55 PM
  #149
RX330inFL
RX330inFL's Avatar
If you have not done a flush by 60K miles I would not recommend performing one. One never knows what all can be unleashed by a flush after that point. Would recommend performing a series for drain and fills to keep the fluid as clean as possible.
BTW, have you ever serviced the power steering fluid? Believe you should look at that as well. Does not use a standard power steering fluid, FWIW.
Old 04-04-14, 07:13 PM
  #150
RXR
RXR's Avatar
2005 AWD 133,000. miles no issues. do a drain and fill with Amsoil every thirty thousand miles. 4 quarts in 4 quarts out
Quick Reply: Any high mileage RX without transmission problem?
