Solved My Headlamp Condensation Problem
My left headlamp (HID-AFS) kept getting condensation in it. I took some Dow Corning valve lubricant and sealant and with my finger I sealed around the turn lamp (where it plugs in)and the large gray plastic plate that covers the AFS bulb. That was three weeks ago and I have not had a problem since. This sealant is good from -40F to +400F and is non curing. If you are careful you can do it without removing the lamp unit. I dried the unit out twice with low heat, but it came right back! After drying it out the third time I sealed it and no more problem.
Wish I was that intelligent. I tore down the headlamp and found the leak. Sealed it where you said above and it was done, no more condensation. Used a silicone seal.
I would have just sealed the top portion (as it was the source of the leak) and be done with it. But I had to take off the bumper and unclip the fender. But learned a lot along the way!
But hey, no more fuzzy headlamp!
I would recommend what you did before tearing the HL apart.
Great idea!
Great idea!
Great idea!
Great idea!
This is the stuff. Only mine is in a large tube that I've had laying arount for about 20 years.
I took the same approach as mandyfig and mmlex1987 for my passenger side headlight, and had positive results. What a relief not to have any more condensation. The price of the Dow Corning sealant vs the price of a new headlight unit (HID-AFS) certainly makes it worth trying...
My headlight stopped working last night, literally! I have an appt with Lexus tomorrow. I asked them to fix it as a courtesy and they said "they would see what they could do."
Fivewilds, do you think you could give me a step-by-step on how to dry the lamps out please (Im a novice)?
Also, how do I acces the part of the headlight that needs to be sealed? Is it just under the hood or do I need to unscrew something and pull something out? Any assistance would be golden!
Thanks guys
Thanks guys
Thanks guys![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks guys
I just lifted the hood and reached in and sealed around the turnlamp and around the plate that covers the AFS lamp. I've had no problem since. Good Luck!
Hope your HID is covered under warranty. It is a bunch of $$.
I set an electric heater about two feet away. It took about 3 hours to dry it out. You might aim it toward the sun for a few hours also - that may do it.
So the dealer said that Lexus issued a "technical bulletin" instructing them to replace the headlight assembly ... not dry out the bulbs and seal around it. Since im out of warranty they told me to just pay the $350 in labor and they would throw in the parts for free. Im gonna def try to seal them myself first.
$350 for a new headlamp assy is not bad. The headlamp itself is $350.00. I bet you they will install a used one.
Anyway try to seal it, you should be ok.
![](http://www.lamin-x.com/v/vspfiles/photos/L008-2T.jpg)
http://www.lamin-x.com/Lexus-RX330-0...ers-p/l008.htm
My solution is to protect
the headlights from the start
with these protective
stickers. Use a blow dryer
to cure to the shape
of the headlights and
now you have added
protection against debris.
