New owner 330 foglight question
Old 02-12-10, 10:33 AM
1111art
1111art's Avatar
Default New owner 330 foglight question
04 330. 41K miles. Everything but the foglights seem to work. I read the manual, but it just mentions twisting the stem to turn them on. I see the markings on the stem, but get no light.
Any ideas how to check if it's wiring, or bulbs, or fuse. Anyone know what fuse runs those, and if it also runs anything else?
Thanks
Old 02-12-10, 10:39 AM
Adamjeeps
Adamjeeps's Avatar
Thanks
Try to turn them on with your parking lights or headlights on. I think one or both have to be on to get fog lights on.
Old 02-12-10, 12:03 PM
mandyfig
mandyfig's Avatar
As you said, could be a couple of things.
Blown Fuse Check your fuse, replace and check, manual will tell you location.
Used up Bulb If fuse ok, can be the bulb, sorry it is pita to replace them.
Faulty-cut Wiring, this will be hard to de-bug, you need to take it in. This is the most remote failure anyway. Gotta be the 2 above.
Finally, Headlamps must be on for the fogs to turn on. This is the typical logic. Some people do mods to allow fogs on with only park lights on.
Hey, that's a potential MOD that nobody's brought up. Any takers?
Paging Mowmow, you are the electrical GURU!!!
Old 02-12-10, 01:33 PM
redrocks
redrocks's Avatar
There's a separate on switch for the fog lights.
Old 02-14-10, 05:03 AM
mandyfig
mandyfig's Avatar
Can you turn on the fogs without the headlamp on?
Old 02-14-10, 06:11 AM
redrocks
redrocks's Avatar
Good question. I've always had the headlights on "Auto" setting.
Old 02-14-10, 07:27 AM
rcy
rcy's Avatar
The headlights must be on for the fogs to work (so they will work in AUTO, but only when the system automatically turns on the headlights). Also, the high beams must be off. The switch is on the turn signal stalk just to the right of the headlight switch. Twist it toward the front of the vehicle for ON.
Old 02-14-10, 11:14 AM
mandyfig
mandyfig's Avatar
That is the logic for the fogs. Generally true for all cars.
Old 02-15-10, 04:52 PM
catdaddylo
catdaddylo's Avatar
Also there is no fog light indicator light that will come on the dash. You will need a mirror or reflection to see if they come on in front of the vehicle, other wise you will just have to get out and look to see if they are on.
Cat
Old 02-16-10, 05:28 AM
mandyfig
mandyfig's Avatar
^^That's one indicator that could have been added.
Old 02-16-10, 06:09 AM
rcy
rcy's Avatar
True. A light in the dash would be nice. My wife's 2010 Equinox has a nice indicator in the dash when the fogs are on. Anyone know if the 2010 RX has it now?
Old 02-16-10, 06:31 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Yes it does, looks just like the one on the 2nd gen.
Old 02-16-10, 08:38 AM
catdaddylo
catdaddylo's Avatar
2'nd generation does not have one. The indicator light bulb with the sun rays is for the headlights. There is not a fog light indicator on the 2'nd generation.
Cat
Old 02-16-10, 09:14 AM
kitlz
kitlz's Avatar
Cat, you're right about the headlight indicator. It looks like a lightbulb. Underneath should be another light with the slanted rays and a slash through them for the fog lights.
Old 02-16-10, 09:18 AM
mandyfig
mandyfig's Avatar
Gotta take a pic and post so we know...
Quick Reply: New owner 330 foglight question
