Red Light on Dash Board?
I'm a new owner of a 2004 RX330. On the dashboard between the Power Rear View Mirror Control Switch and Power Back Door Opener/Closer Switch is a red light that stays lit in the spot where the Easy Access Mode Switch should be. The dealer had no idea what it is. Does anyone have the same setup?
Yes a pic will help...
9/10 Security.
Accurate description would be in the user manual.
Although a bit more zoomed out picture would have been better.
Salim
Salim
Red Light on Dash
Thanks for trying. The security on the dashboard is active. If it is a security light is must be an aftermarket system. I looked in the owners manual but there is no option or explanation for it.
Red Light on Dash
Is there any electronic wizzes out there that professionally install aftermarket alarms and/or starters? If so, what would be the ohm/voltage reading on the hot and neutral wires for an alarm versus a remote starter? Maybe I can narrow it down from there.
Does this stay lit all the time or only when the engine is off? It is a possibility this is a "fake car alarm" but they are suppose to flash only when the engine is off, even if the car is unlocked.
Red Light on Dash
