Just Installed Short Ram Air Intake
Old 02-23-10, 07:22 AM
ppatel821
ppatel821's Avatar
Default Just Installed Short Ram Air Intake
Hey guys,
I just got done installing a short ram air intake into my '07 RX 350. I installed a Weapon R Secret Weapon Air Intake. Took me about 30 minutes to install. It sounds absolutely amazing and I can feel the slight increase in hp. Its suppose to increase mpg, however I love the sound of the intake so I tend to punch it a lot haha.
Ive included some pics.
Lemmie know if you have any questions.
Attached Thumbnails Just Installed Short Ram Air Intake-photo.jpg   Just Installed Short Ram Air Intake-photo-1.jpg
Old 02-23-10, 07:32 AM
lexus114
lexus114's Avatar
Looks good,did you reset the ecm?
Old 02-23-10, 09:42 AM
mandyfig
mandyfig's Avatar
Is it plug and play? How much?
Old 02-23-10, 09:44 AM
mandyfig
mandyfig's Avatar
Wonder if it is the same unit for the RX330...
Old 02-23-10, 09:46 AM
mandyfig
mandyfig's Avatar
I hate replacing the air filter on my 330. The space is so crammed in there. The freeking bracket in the corner prevents the top cover to seal back, and not allowing the hinge to slide in! PITA!!!!
Good that you replace it 1x year!
Old 02-23-10, 09:47 AM
mandyfig
mandyfig's Avatar
Maybe they have corrected this later. They have to. Mine's built in 2004 early, one of the first ones that rolled out of the Canada plant.
Old 02-23-10, 12:16 PM
HimSelf
HimSelf's Avatar
Is there a way to get fresh air into that filer? I have seen other mods on different cars that has a scoop or some just use a tube to get fresh air up from the front gril or the bottom to the filer.
Old 02-23-10, 01:14 PM
Lexmex
Super Moderator
Lexmex's Avatar
It's a much tighter fit on the 2nd and 3rd gen RXs than the first, but doable.
Old 02-23-10, 05:08 PM
Rainbird
Rainbird's Avatar
A FlowMaster in the rear and your all set!
Old 02-23-10, 05:56 PM
Boognish
Boognish's Avatar
I'm glad you like it, but I highly doubt you're making any more power.
One of the reasons my wife wanted the RX was that it was quiet...to each their own.
Old 02-24-10, 07:07 AM
aquatrax
aquatrax's Avatar
Also, you're not doing yourself any good by sucking in the hottest air at the top of the engine. You want cold air because it is denser. I had on of these in a previous car and the tube went all the way to the wheel well to get the coldest air.
Knappy (07-16-24)
Old 02-24-10, 11:56 AM
Lexmex
Super Moderator
Lexmex's Avatar
I think a few years ago, when still in Mexico, I had a thread about where one could have a snorkle pipe down to suck in cooler air. I plan on doing some upcoming air intake modifications with my RX300, but the 2nd gen RX is a much more difficult puppy in part because they moved the tranny cooler from the passenger side to the driver's side, but it still would be possible maybe with flexible tubing to attach a hose from the front of the filter and stick into the side of the body frame to draw cooler air from their. A heat shield could help somewhat.
One of the other things I did to cool that area was remove the rubber cladding that. See blue line below based on above picture.
Old 02-24-10, 12:16 PM
MrBruin09
MrBruin09's Avatar
Buy this heat shield and you should be set!
http://www.weapon-r.com/english/inde...ndex&cPath=537
Old 02-24-10, 11:01 PM
ppatel821
ppatel821's Avatar
It is the same unit for the 330 and it ran me about $200.
Old 02-24-10, 11:13 PM
ppatel821
ppatel821's Avatar
Yes, colder air is better because it is more compressed therefore it contains more oxygen my volume which results in more combustion, however in a vehicle like this where is it very easy to get water into the intake, it is not safe to have it that low. The kit came with a pipe to place the filter wherever it chose, but for now, this is fine. im not trying to get water and more dirt sucked up into the engine.
Quick Reply: Just Installed Short Ram Air Intake
