programing for 2007 lexus rx350
hey guys i been searching all over. and i have not found any guides about programing 2007 rx350 remotes.
i lost all my remotes. and only have 1 key left. i wanted to buy the remotes+key online and get it cut in the store then program it myself. because it online cost $90 for the remote+key and $30 for cut.
while the lexus dealer told me it would be $265 for key+remote then $129 for programing.
I found this in the internet:
For 1998+ Toyota, Lexus
Add Duplicate Key
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and
remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
For 2002+ Toyota, Lexus
Add Duplicate Key
Requires one working Toyota/Lexus Master Key.
1. Make sure all doors and windows are closed.
2. Insert Master key into the ignition cylinder.
3. Cycle the ignition cylinder from On to OFF five times.
4. Open and close the “driver side” door 6 times.
5. Remove the Master Key and insert the new duplicates key.
6. TURN THE IGNITION CYLINDER ON.
7. The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
Another method to program the remote:
1.with no key in the ignition an the drivers door open and unlocked
2.within 4-5 seconds put the key in the ignition and remove 2 times
3.close the drivers door and open 2 times
4.put the key in the ignition and remove
5.close the drivers door and open 2 times
6.put the key in the ignition and close the drivers door
7.turn the ignition to ON for 1 second then turn OFF
8.remove the key from the ignition
9.the power locks should now cycle once
10.press the unlock and lock buttons at the same time for 1 second and then quickly press the unlock and lock buttons for 1 second again
11.if the remote is programmed the door locks will cycle once. If failed the door locks will cycle 2 times
12.open the drivers door to end the procedure!
Add Duplicate Key
remove key.
Add Duplicate Key
