Problem encountered with Mobile 1 oil filters
Hello,
I was wondering if anyone else has experienced the same problem. I purchased two Mobile 1 oil filters M1-102 from the States as they cannot be purchased in Canada. This is the filter Mobile 1 indicated was for my 05 RX330.
So I was at the Toyota dealer today for an oil change. However, to my dismay the Mobile 1 filter would only partially threaded. So the technician tried the other filter, and it did not work either. So at the end of the day a Toyota oil filter was put on.
I send an email to Mobile 1 from the dealership, still waiting for a response.
Any suggestions?
Any suggestions?
Hello,
Any suggestions?
Any suggestions?
I use a larger K&N HP-2009 (the stock one would be the HP-1002) and incidentally, they both will fit your vehicle as well.
For Mobil 1 I also saw an MO241 listed.
I wanted better filtration and more flow and since I run Castrol Syntec 0W30 (aka German Castrol) I run 7000 miles (I could run longer), a normal size filter wouldn't have the same flow/filtration at 7000 miles.
I learned of this filter from some Toyota Tacoma owners.
Still can't figure out that Mobil 1 filter issue you had. I'll have to take a look at one of them next time I go to an auto parts store and compare it with a K&N.
