Power Steering fluid change 2005 RX330
Old 03-11-12 | 12:37 PM
  #31
RX330inFL's Avatar
RX330inFL
BTW, for those thinking of replacing the power steering fluid it is really quite easy. I had a bottle of Resolve carpet cleaner ready to go out the recycles some time back. So, kept the trigger assembly and cleaned it out. I also have a 2L soda bottle which the trigger conveniently screws on the top when not in use.
Remove the power steering reservoir cap, stick the hose from the trigger in the tank, pump the fluid out and into the 2L bottle. Fill, replace the cap and you are set to go.
Old 03-12-12 | 07:25 AM
  #32
infinirx's Avatar
infinirx
How long should this take to complete?
Old 03-12-12 | 01:51 PM
  #33
RX330inFL's Avatar
RX330inFL
Took me only minutes. Not a lot of fluid to pump out. Perhaps 4 oz.
Old 03-18-12 | 11:55 AM
  #34
jconst6558's Avatar
jconst6558
Originally Posted by RX330inFL
Back on the topic of changing the power steering fluid...
Has anyone noticed a varnish coating building up on the inside of the power steering fluid reservoir over time? Had been a bit since I last changed out the fluid so popped the hood this morning and pumped out what I could of the old stuff. When I looked at the outside of the reservoir it still looked like there was fluid in there even though when I looked from above I could see I had pumped out all that was in there. Had to be a coating from some of the old stuff in the system. Made it a bit difficult to see how much I was putting back in.
Will be swapping out the fluid on a regular basis for a bit to clean out the system, however, this concerns me some about this varnish and contaminants in the system. Am not going to attempt to put any cleaners in the system for concern over damaging hoses or gaskets. Still, wondering if anyone has any thoughts on this and possible solutions?
Am considering draining the reservoir, removing it from my RX330 and then clean it out separately as best possible before reinstalling it.
Thoughts are appreciated.
Just changed my fluid yesterday. '04 with 62k on it. The dipstick and reservoir had this same dark varnish. I used carb and choke cleaner on the dipstick but couldn't clean the reservoir. You're right, it's impossible to see the fluid level. Only thing I can think of is to buy a new fluid reservoir. I'm not going to do this though; I'll just live with it. BTW: I did the complete flush and used Amsoil synthetic atf.
Old 03-18-12 | 12:27 PM
  #35
RX330inFL's Avatar
RX330inFL
I picked up a can of Sea Foam Trans Tune. Thought I would empty the reservoir and fill it up with this stuff then let it sit overnight without running the RX. Then, empty and refill with proper fluid. Stuff says it dissolves varnish, so am going to see if it does what it says. Will break out the camera and take pictures if I remember.
Old 03-18-12 | 01:26 PM
  #36
infinirx's Avatar
infinirx
I did this with my buddy. The dipstick and reservoir had this same dark varnish for me as well. Just a drain and fill though. You can see the levels if you have a powerful LED flashlight and play with the angles just kind of annoying. I can live with it. Now that I ha this done it's time to bring the car in for the Pulley TSB.
Old 04-23-13 | 12:40 AM
  #37
pablo87's Avatar
pablo87
Did my 05 Rx330 this past month for the first time ever after 125K miles. Fluid was brown/black. Was still dirty after the first time so did two more 100 city miles apart finally its pretty clean. Used t-iv tranny fluid. I got more than 4 oz. Out Each time (followed rx330fl's tip) as I've used half of a 32 oz bottle. Had a hard time seeing the level too though if you look as you're pouring, you can see the liquid level rising.
So far this has been the best DIY investment for me - $3 of fluid for a much better steering experience.
Old 04-23-13 | 10:29 AM
  #38
RX330inFL's Avatar
RX330inFL
OK, we need to take a step back here. Method is fine, however, I am concerned on your choice of fluid. You say you used Type-IV. You should have used DEXRON II/III. This is right out of the Owner's Manual:
Power Steering fluid change 2005 RX330-screen-shot-2013-04-23-at-12.23.23-pm.png
Go check the bottle of fluid you are using. If it does not say it is compatible with DEXRON II/III it is not. Personally, I go along with LEXMEX and others here by using Mobil 1 ATF which IS compatible with DEXRON II/III.
Old 04-23-13 | 02:58 PM
  #39
mandyfig's Avatar
mandyfig
This is what I heard recently from a Toyota technician, true or not it does not bother me, I will use T-IV no matter what:
T-IV fluid is simply a Dexron III fluid.
Old 04-23-13 | 03:04 PM
  #40
RX330inFL's Avatar
RX330inFL
It could very well be when you get down to nuts and bolts. However, being the skeptic I am I tend to be a bit cautious and if it is not stated as being compatible I am in the group not using it. Besides, I do not keep Type-IV around, but I do have Mobil 1 ATF for other uses and other vehicles.
Old 04-24-13 | 09:31 AM
  #41
pablo87's Avatar
pablo87
Attachment 281016
Right you are but I did some research and found that Toyota type IV was just more refined DEXRON III, and that's what I had on hand. Probably more expensive though than the Mobil I ATF ($5.15 per quart what the T-IV costs me).
350rx
02-04-17 05:24 PM
JonCAGS300
GS - 1st Gen (1993-1997)
01-06-08 08:51 AM
stroker
12-11-07 09:46 PM
Kharizma
05-05-06 09:06 AM
Purplexed
Maintenance
05-26-01 07:16 AM
