Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- How to Align Your Tires
Step by step instructions for do-it-yourself repairs
Steering Wheel Alignment issues on 04 rx330
Hey guys,
I picked up a rx330 last year, i am noticing the steering wheel is slightly tilted to the left. I went to a local alignment shop and the guys did the alignment, even rotated the front two tires, then re-align.
It improved a little the steering wheel came straight. But when going straight it still tilts a little to the left.
I don't have uneven tread wear..
anything you guys can recommend?
Thx.
Thx.
Explain this a little more. What is your issue? Is your steering wheel not centered? meaning left of 12 oclock? You paid for the alignment, the wheel should be dead center, that's part of the alignment process.
The steering wheel is centered when the car is parked, the wheels are straight.
However when i drive the car the steering wheel is tilted slightly to the left. There are curb rashes from the previous owner so the alignment shop is indicating that the wheels maybe damaged.
Tires don't have uneven tread wear. Looks like i may take it in to Lexus to have them look at it
Tires don't have uneven tread wear. Looks like i may take it in to Lexus to have them look at it![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Let me get this straight:
1. There's no pulling?
2. When you are headed straight on the road, is the steering wheel straight?
3. Any vibration while driving?
4. You are not losing air?
If you answered NO to all of the above, then we can surmise:
1. Rims, tires are OK, do not believe the alignment shop.
2. They did not do a perfect alignment.
Get money back from alignment shop, unless they re-align your steering wheel, which means they have to adjust the tie rods.
Pros, comments please!
^^ Heh..heh..heh..I'm with you mandy
If there is no pull while driving straight, your adjustments were done right. And your tires will not wear unevenly as Lexus114 mentioned.
Now if your steering is off-center while driving straight.
Then the tech didn't center your steering wheel correctly.
When I get my alignments done, I usually ask the service writer if I could center my steering wheel before they do any adjustments.
So the steering wheel is where I want it to be. Dead center.
But if it's just a hair off and but still tracks straight...I wouldn't loose sleep over it.
Of course road crown is always an issue. Lol..
i did feel a slight difference, but my steering is just a tad bit off to the left while driving.
No vibrations, pulling, or loosing air.
just the steering wheel is off a tad bit to the left... i went to a mom and pop foreigner alignment shop since i did not want to wait around at the dealer or a franchise shop like Firestone...
I guess i need to go back
Set your tire pressure to 34 psi. Recommended is 30 psi. Why the heck do they have it at 44 psi?
Crazy sheet!
Crazy sheet!
so today i went to my local pepboys to do the alignment and told them the whole situation regarding the alignment.
yada yada yada and $80.00 later my steering wheel is tilted to the right now when i drive straight...![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
i will wait a day or two if the issue is not corrected i am going to have to take it back..
Stupid Lexus needs 1 full day to do an alignment and i don't have a secondary car...
Alignment with a loaner at a Lexus dealer will cost an arm and a leg.
Take it to a reputable tire place, get it re-aligned if you do not want to go back to your other place. I would not see them again, obviously they did you wrong.
