High Octane Myths (Dealer Newsletter)
I receive a monthly newsletters from a local Lexus dealer and they had the following article on High Octane Fuel.
High Octane Myths – What Does That Number at the Pump Really Mean?
The truth about Regular, Plus and Super gasoline.
In the automotive world, there are many common myths, which are repeated so many times that, after a while, they eventually transform themselves into ‘facts.’ Unsurprisingly, many of these ‘facts’ have to do with gasoline, whether they be regarding fuel mileage, power possibilities or some other arcane aspect of the internal combustion engine. Gasoline can be a confusing topic, and it is easy to make assumptions about it that may seem logical, but which on closer examination, turn out not to be true. A perfect example of this practice can be seen with octane ratings.
What are octane ratings? Simply put, when you pull into the gas station and are presented with the array of different fuel grades that you can pump into your car, the numbers written above each button or nozzle indicate that particular grade’s octane rating. Typically, the range will run from 87 octane on up to 93 octane.
In the world of automobiles, it is tempting to associate higher numbers with higher quality. After all, more horsepower and more miles per gallon are a better thing, which feeds into our perception that more impressive octane ratings also equal higher performance. Gasoline companies understand this mentality and do nothing to dissuade drivers from it, labeling 87 octane gas ‘Regular,’ and 91 or 93 octane ‘Super’ in an attempt to reinforce this way of thinking. After all, since ‘Super’ is priced higher than ‘Regular,’ it’s in their best interest to convince as many people as they can that paying a bit extra means getting better quality gas.
Unfortunately, this is where the myth of what gasoline’s octane rating really means creeps into the picture. Time and again, people will be told that high octane fuel burns cleaner or more completely, and that it will give them extra power and better fuel mileage than Regular octane gasoline because it contains more ‘energy.’ These blanket statements are simply not true. In fact, the octane rating for gasoline has nothing to do with the amount of power locked inside of it – it actually relates to just how much a fuel can be compressed before igniting. The higher the number, the less likely it is to ignite under pressure.
Why would anyone want to produce a fuel that was actually harder to ignite once inside an engine? To understand the role that octane ratings and ignition pressures play in a motor, it helps to be familiar with the term ‘knock.’ Essentially, when gasoline is sprayed into a cylinder by a fuel injector and mixed with oxygen, engine designers expect it to remain there in vapor form until it is time for the sparkplug to light it up, causing the explosion that drives the piston down to generate horsepower. The timing of this explosion is critical, as gasoline that ignites too early causes ‘knock,’ which reduces engine output and efficiency and which, in worst-case scenarios, can actually physically damage an engine.
In most engines, knock is rarely an issue because the compression ratio – that is, the pressure that the air/fuel mixture is put under in the cylinder – is low enough that Regular gasoline’s octane rating is sufficient. There is absolutely no benefit to running Premium fuel in a standard motor, since it will never be able to take advantage of that gasoline’s higher knock resistance. However, more aggressive engine management schemes, especially those found in turbocharged or supercharged vehicles, can turn up the compression to a high level, requiring much higher octane gasoline to avoid knock.
How can you know whether your car actually requires Super gasoline or whether it can get by on Regular? Almost every vehicle will list the octane rating necessary to run it safely inside the owner’s manual. Some luxury or sportscars might even place a small reminder on the gas gauge itself stating ‘Premium Unleaded fuel only’ to make sure you don’t forget
To wrap things up: no, you won’t see a power or fuel efficiency increase by running high octane fuel in an engine that has been tuned and designed for Regular gas, nor will doing so perform any extra ‘cleaning’ inside the motor. On the flip side, running low octane fuel in an engine built for Premium can increase the risk of engine damage and will certainly impact that unit’s overall performance. The next time someone tries to pass these myths off on you, you can try explaining to them how octane ratings really work – or you can just smile and nod, pay for your gas and move on.
Published by Arlington Lexus in Palatine
my owner's manual for my 2004 RX330 says I can use 87 rated gas. Does that mean that "regular" gas is ok and that using it wont damage the engine? I've been confused about this for a while. Any insight is appreciated.
That's the vehicle that I have and that's exactly how I'm interpreting it.
Very well stated.
Just a couple of clarifications.
Running a lower octane than recommended will probably result is some power and economy loss because, to prevent knock, the computer has to retard the spark more than optimum.
Higher Octane products may allow the engine to run cleaner (internally clean - not emission clean) because some, but not all, brands have a superior cleanser package in the higher octane products.
And an interesting aside.
In 1988 I bought a beautiful new bright red BMW M3. Due to the high performance and high compression four cylinder engine, BMW required a minimum of 91 Octane and made this very clear in multiple places. At that time my wife and I were dating and we were getting serious so it was natural for her to sometimes drive the M3. I, of course, explained to her to not even think of filling with anything other than "premium" gasoline. An Exxon station in out neighborhood had three grades of gasoline; Regular (87 octane), Premium (89 octane), and Super (92 octane). You guessed it, verbatim compliance ruled and she filled it with the Premium 89 octane. I called BMW NA (not the dealer) and they very emphatically told me not to drive it and have it towed to have the tank drained. I did drive it about 20 miles, with very light throttle application and very low revs to my mechanic. They thought I was crazy but they drained the tank. I learned an important lesson about communications that day.
the article is old news but what about in my case? my '04 RX330, regular unleaded fuel only, had the transmission lag/shift problem and was flashed by the dealer. the service dude told me that i will need to pump premium fuel from now on since the ecu has been flash to something something...i don't remember his exact words. if i continue to pump regular, the problem may get worst and they won't be able to re-flash it again. fearing for the worst, i have been pumping premium ever since. the problem is much less pronounced but sometimes i still get that jerk/lag from 2nd to 3rd. so, my question is....does my RX330 really need premium bec. of the ecu flash or have i just been wasting my money?
Very well stated.
and your point is?....did 89 have any affect at all?
No effect on the 89. Had it for about 100K miles after that. Point of this incident was how adamant BMW NA was about not driving the car with 89 octane gas in the tank. Although this was 22 years ago the car still had a knock sensor and a sophisticated engine management system. I would have thought it could have safely handled the 89 octane gasoline, albeit at the loss of performance, but BMW NA seemed to think otherwise. They were obviously concerned that there was a consequential risk of detonation with 89 octane gasoline. This makes me think twice about using an octane lower than recommended with the Lexus and BMW we currently have. Saving money on gasoline is a poor economy if one is risking damaging the engine. Without knowing for sure, I am taking no chances.
Lexus recommends 91 octane or higher for the 330. I have used 89 octane with better millage results. But it does have the most power on Premium fuel.
