Cleaning Plastic on Door Panel
Need some ideas. What is the best product someone has used to clean the plastic on the door panel.
Near the speaker, I have some scuff marks from shoes. I haven't found anything that removes the scuff marks.
Degeaser is what I use. Takes care of it. Or else, use fine polishing compound.
I've had good results using Meguiar's M39 Heavy-Duty Vinyl Cleaner for cleaning scuff marks. I'd follow with a good protective dressing to make future scuffs easier to clean.
De-greaser and then polishing compound if need be.
Magic eraser is a tool of the trade in our business. Different grades will induce different results. Yes I forgot about the eraser. We normally use the eraser for blending in "blush."
I can also say that Mr. Clean Magic Eraser works wonders. Just be very gentle and don't press too hard. Also, make sure to rinse the area well. When I tried it for the first time, there was a residue left behind.
