A/C on driver side is warm
Why would my driver side air conditioning be warm when set at the same temperature of 60 degrees as the passenger side? I have a 2009 RX. Thanks!
Do you have it on dual, and is there some reason (like shade differences) that the passenger side would be warmer therefore triggering AC on that side. I presume all the vents are equally open.
we had this problem in our 08 Avalon. took it in for repair and they couldn't find anything wrong. then they decided to check the freon levels...sure enough, they were low. they re-charged the A/C and added dye. we'll keep an eye on it. all under warranty. apparently when the freon is low, only one side will blow out cool air. why the hell it's the passenger side and not the driver side is beyond me.
nosurprise
10-10-13 08:24 PM
