Passenger Arm Rest Squeak
I have a small squeak I guess you could say, from the arm rest of the front seat passenger door. I'm in Australia and hence my car is a right-hand drive car. The passenger when putting their arm on the arm rest of the door, the arm rest will squeak / rattle / creak with the movement of the car. This seems to be the point where the rear of the arm rest meets the rest of the door. I can make it perform this squeak / rattle / creak by simply applying a bit of pressure to this point. Is this a known issue or is it probably going to be that that piece has come loose and just needs tightening (which is what I believe the problem to be).
This picture is of a left hand drive vehicle, but illustrates the spot I am talking about
![](http://www.amnet.net.au/~draco3/NewRX/Pressure.jpg)
Can I get to the screw that holds this in place quite easily or is there a complicated process to get to it?
SenecaRex
08-14-15 04:20 PM
