Maint. Req'd
The manual is your best friend. It should tell you how to re-set the maintenance required light.
Also, search can do wonders here, too.
Welcome anyway.
Welcome anyway.
Make sure the odometer is set to total miles not trip. With the key in the off position, push in and hold the odometer button (ODO). Turn the key to the on position without starting the car. Continue to hold in the odometer reset button until the maintenance required light goes off (about 20 seconds).
