So i got a bunch of LEDs - RX series.
#32
#33
How about DRL-daytime running light for 2008 400h? Put in a pair of eBay so-called 68 led but half of the bulb is lit up. I guess is the 1/2 power output. But looks good on my 2011 450h except not quite as bright. Any suggestion?
Wil
Wil
#35
Does anyone know how to change the accent lighting? The orange lights near the feet in the front. Driver side and Passenger side. Which bulb does that take?
#36
Great work and photos! You've inspired me to start doing similar.
Do you remember the type, size, wattage (lumen, etc) that you used for the vanity mirror LEDs? And any tips about prying off the clear plastic piece? Just use a thin flat screwdriver at various points, or just finger nail?
cheers
Satz
cheers
Satz
#38
this afternoon i installed the 3 trunk lights, license plate lights, front door panels, and rear dome light
i have more leds coming in the mail: 4 vanity lights, another 36 led board for the front dome light, 2 for the map lights, led fog lights, and led parking/driving lights
#39
thank you all,I want to replace the reverse lights,blinkers and brake lights,what kind of bulbs did you use,i mean size ,color and also please the high beams ,,,thank you
#40
HID-D2S
High beam headlamp
9005
Parking light
168
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
168
Stop light
7443
High mount stop light
Assembly
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
168
Rear sidemarker
168
Glove box
74
Dome light
DE3175
Reading Light
BA9
Step/Courtesy light
2825
Trunk/Cargo area
DE3022
#41
Bummer! Got some 194 LEDs but they're too long to fit inside the license plate light housing. Oh well...used them for my doors instead and will keep searching for new plate lights.
#43
Hi Normi
In regard to the footwell (and glovebox) lights. I changed mine on my 07 RX recently. Replaced the existing orange LEDs with white ones.
Easy enough to access the footwell lights. They're behind the kick panels. The one on the driver's side you can reach without removing the panel. Just reach behind and twist the light unit (small rectangular box approx 30mmx10mm) about 45degrees and it pops backwards. Then disconnect the wiring harness.
The one on passenger side requires you to unclip the kick panel (3 clips at the front edge) then slide out.
The little LED boxes can then be opened up (see my separate thread on this topic)..and that's where the difficult part is! Getting the old LED off!
I used 3mm clearwater white LEDs in place of the original orange ones. Widest angle I could get were 20degree. Try to find something around 45deg.
cheers
Satz
cheers
Satz
#44
hi
could you please post the sizes of festoon LEDs you used for:
Vanity mirror (was it 31mm 2 x SMD warm white?)
Ceiling light
Map light
Door puddle lamp
I'd love to be able to order these before taking apart my lights as there's nowhere in my town to buy off the shelf![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
btw, to the OP, what happened to the many photos that were here showing how you removed the vanity mirror, cabin lights, etc? They were fantastic
Ceiling light
Map light
Door puddle lamp
#45
Hi Normi
cheers
Satz
cheers
Satz
Also I changed all my interior lights too. Will be posting pictures ASAP since I still have some minor changes to do
