Spark plug change?
Old 10-27-11, 08:37 AM
  #31
RX330inFL
RX330inFL's Avatar
Originally Posted by Lexmex
Unless you are going to do some major performance modification, I'd stick with stock plugs.
Is that in reply to the post from diverchris regarding TorqueMaster?
NGK I consider stock.
Old 10-27-11, 08:43 AM
  #32
Lexmex
Super Moderator
Lexmex's Avatar
No, in general. If you aren't modifying, I'd stick with the OEM plugs.
I just saw his post there. I use Torquemasters and they work well for me, but when I tried them with a practically stock RX300 in Mexico the first time around, no difference. It came to life once I had the intake/exhaust modifications in place. My cousin has a Golf VR6 and still has them and got some much better emissions test scores after using them, but again he has a modified intake exhaust and a host of other modifications in the engine.
Old 01-19-12, 02:36 AM
  #33
LophatRX
LophatRX's Avatar
I have seen the NGK iridium plugs from Pep Boys or Orielly auto parts $8.00 from the previous and 7$ from the next. I am considering taking on this job my self too, I have pretty skinny hands. The only problem I don't think I have a good bent socket wrench like the one in one of the pics. I have the short handled socket wrench though.
Old 01-19-12, 06:05 AM
  #34
thomas1
thomas1's Avatar
Stick with the iridium plugs, even at 125k miles they look new. The rears are a pain on the RX300, but I Have not attempted the RX400h yet....still have miles to go. I have removed the windshield cowl when I did the timing belt. not a bad job at all...Use blue masking tape on the windshield to mark the location of the wipers for reinstall. I still had to move wiper a notch even with that, but removing cowl gives you a lot more room and visabillity.
Old 07-11-16, 08:27 AM
  #35
dganapol
dganapol's Avatar
I know this is an old post, but it just confirmed that if we remove the wiper cowl on an RX 350 we can remove the passenger side bolt holding the intake on. I spent 14hrs on my back in the engine compartment removing the bolt. Don't ask.
David
Old 07-25-16, 09:25 AM
  #36
mandyfig
mandyfig's Avatar
Just did my timing belt and the plugs on the 330 and it is worth removing the cowl and the intake for the rear plugs' change. Trust me, I saw the whole process.
alchemist
04-08-24 11:19 AM
sprint72
12-02-19 06:54 AM
/Aerostar\
Performance & Maintenance
05-15-12 07:46 PM
nicks88
09-22-11 01:13 PM
ISguy
Maintenance
06-06-06 05:43 AM
Quick Reply: Spark plug change?
