Rattling Noise When Starting - Need Help
Old 05-31-10, 12:39 PM
ppatel821
ppatel821's Avatar
Default Rattling Noise When Starting - Need Help
I have an '07 RX 350
When I start my car, I hear a rattling sound from the engine. It only happens after cold starts however. Ill turn the car on and immediately after I release the key, the rattling occurs. It always occurs during cold weather, and occasionally during warm weather (I live in Florida).
I took it in to Lexus cause its all under warranty, but it just so happened that when they did the cold starts, the noise did not occur.
Any suggestions?
Old 05-31-10, 02:00 PM
cmichael
cmichael's Avatar
Any suggestions?
Keep it parked at the dealership. Problems are never duplicated there.
Seriously, have someone else start it while you're under the hood. Could be the higher RPMs on initial startup is causing a loose part to rattle.
Old 06-01-10, 10:21 AM
HimSelf
HimSelf's Avatar
I had this same problem this winter. The noise would stay for a min when I start in the cold and then goes away each time. since is summer now the problem went away.
Old 06-01-10, 11:39 AM
mowmow
mowmow's Avatar
Are you guys using synthetic motor oil ?
Old 06-01-10, 11:50 AM
mandyfig
mandyfig's Avatar
I do have a crackling sound which started recently. It is so irregular, but consistently crackling, similar to popcorn po, but instead crackling.
Old 03-02-12, 02:41 AM
ManXP
ManXP's Avatar
Any luck solving it? I know this is very old topic, but maybe you found and fixed the problem? Sometimes I have the same issue; rattling noise from engine for 1-2 seconds after I start the engine and release the key.
Old 03-02-12, 07:20 AM
lexus114
lexus114's Avatar
Are you Guy`s talking about the "Death rattle" that occurs from bad anti drain back valves in the oil filter?
Old 03-02-12, 07:28 AM
ManXP
ManXP's Avatar
What is it? I entered Death rattle into forum search and found only 4 topics, but NONE of them describes the issue.
Old 03-02-12, 07:32 AM
lexus114
lexus114's Avatar
If you have a can type oil filter, some times the drain back valves dont work properly. Which allows the oil to escape out of the filter, thus creating a dry start each overnight start. But, if you have the filter that is not the canister type, this should not apply. I have found the absolute BEST canister type oil filter to be the Bosch Distance plus filter. D3330 Terrific filter, and I never get the rattle of Death on this filter . However it is a very expensive filter.
Old 03-02-12, 09:53 AM
ManXP
ManXP's Avatar
I don't think it's filter issue. The car has always been served at Lexus dealer, so I guess they place the proper filter every time. Anyhow, next service is due in 500 km... Who knows, maybe new filter will fix it...
Old 03-02-12, 09:54 AM
lexus114
lexus114's Avatar
I`v had bad Denso/Toyota filters before too. Not often though.
Ronman15
ES - 6th Gen (2013-2018)
15
02-21-14 02:12 PM
737NG
08-21-12 08:58 PM
realchimer
01-09-12 08:26 PM
nyardich
ES - 5th Gen (2007-2012)
17
01-05-11 11:33 AM
tqlla3k
09-25-07 05:55 AM
Quick Reply: Rattling Noise When Starting - Need Help
