How do you adjust headlights?
Had the front bumper cover and a headlight replaced. I thought that the lights previously had been aimed to low. That very distinct cutoff on the low beams seemed to limit the distance the beam covered out in front. So, I asked that they aim them higher while they were messing around aligning them.
Now, they are too high. Where are the adjusters, which direction do I turn them to move them downwards and can you equate adjuster rotations to inches or such to estimate how much each turn on the adjuster will pull the light down?
If you have HID lights, various posts seem to imply that the 'best' adjustment is done via adjusting the lever (in no small part, probably, because it adjusts both lights equally at the same time). Otherwise, you need to adjust each light separately, which is more difficult to do accurately. Since you just indicate that your lights (both??) are too low or too high, I would assume the preferred adjustment - if have HIDs - would be at teh suspension rheostat. Good luck!
ehryciuk
ES - 5th Gen (2007-2012)
41
08-24-22 06:33 AM
