2004 RX330 w/20" rims
Stock widths on the GT-R is staggered, Look at all these EVO and Skyline time attacks running staggered wheels and/or staggered width tires. Width and offset doesn't affect ratio.. running height of wheel and tire do.
This is my buddies quote Hmmmm
I would love to know where the rumor came from about staggered rims on AWD cars can damage the drivetrain.
Jeff92se I agree and it's really hard to find classy wheels for a crossover luxury SUV. However I think the ones your showing are too TRD style. A bit bland for a Lexus. It's all personal choice. I would like those wheels on a blazer or explorer.
When you go to test fit, be sure to take pictures so we know how it fits. At the least take note of fitment in the wheel wells.
Let me restate what I'm trying to say as I think I might be saying it wrong.
For our cars, we need to use different offsets in the front and rear to get the wheels flush with the fender, but using the same width in the front and rear.
For example:
front = 22x9 +35
rear = 22x9 +15
tires = 265/35/22 on all 4 wheels
This should bring the wheels flush with the fender and also allow for tire rotation to get the most out of the tires.
I will edit my post above so I don't mislead anyone.
For example:
front = 22x9 +35
rear = 22x9 +15
how can you rotate when the offset's different? wouldnt look really weird? wide front and narrow rear?
i found this great calculator. Anyone knw the offset of our oem rims? is it 7.5 width and +35 offset? looks like if you want to run 9" wide rims you'll need +15 offset in order to have same backspacing as 7.5 wide +35 offset.
http://www.1010tires.com/wheeloffsetCalculator.asp
also, I wouldnt plan on rotating your tires with a staggered setup. You'll have to strip and remount with more tires being directional.
uhh... a 7.5 with +35 is WAAAAY more conservative than a 9 with +15. At that point you'll likely have the rim sticking out of your fender. I dont know much about RX wheel fitment atm, but thats closer to SC sizing. You would likely have to run that same +35 or possibly go with a higher offset if you're wanting to retain stock-like fitment. If you want something more aggressive then a lower offset is def the way to do that.
That site I think is amazing. Better than the other calculators just cause it deals with the rim and not the tire. The others are useless if you dunno what tire you need.
Does anyone know the specs on the chrome 18" stocks for the 205 330 off hand?
also found this. gives you the offset and looks pretty flush!
http://articles.dashzracing.com/wp-c...-vip-style.jpg
niiice, aggressive is good. Thought you were trying to retain oem fitment. You keeping stock suspension?
at most maybe a subtle lip in the future, but mostly just wider rims. The design of the body and the narrow rims make it also look very top heavy.
I really like this guy's setup and think something like this would look great on my black RX. Unfortunately he posted a few pics and vanished. I think they're 20x9 IIRC.
ok so a little about staggered setups on AWD cars.
Can it be done? Yes. Lots of AWD cars have them including the GTR, so what's the issue? well, if not done properly, a staggered setup can ruin a AWD system because the front and rear wheels are different circumferences. This means they're spinning at a different rate which causes the computer to think that either the front or the rear are always slipping. This can ruin your center diff. Now as long as you keep the same circumference in both the front and rear wheels, you can run a staggered setup.
2 different types of staggers:
1. larger rim wheel and smaller front rim such as found in the NSX and corvette (ie. 17x8 front and 18x8 rear)
2. wider rim wheel and narrower front rim (ie. 18x8 front and 18x10 rear)
So now you think if you go with the 2nd type of stagger (narrower front, wider rear, but overall same rim size) the overall circumference of the rim + tire will be the same and no problem? Yes thats correct, HOWEVER you will need to run diff sized tires as well, ie. 245/45/18 front and 285/45/18 rear. Obviously if you run 245/45/18 tires on both an 8 and 10 inch wide rim, the rear will have much smaller circumference because of the stretch.
Now if you run same rim + tire spec front and back except the offset is different to achieve that staggered look, this is perfectly fine and you wont have to worry about different tires as the rim is the same width and overall circumference still the same.
Hope this clears it up. Now for those thats going to order your own rims and not get a wheel shop to do all the calculations, here's a tire size calculator that tells you the circumference differences in different sized rim applications:
http://www.miata.net/garage/tirecalc.html
word has it is if you keep the difference under 6 revs/mile, it's safe enough for the AWD system. This however is not scientifically proven so do so at your own risk. Safest route is just to go with same spec rim + tire with diff offset.
