Wheel Fitments for RX330
I was searching for a wheel fitment link for the RX330 but unable to find anything. Wondering if anyone had a link or if anyone knew if 20x9.5 or 19x9.5 35 offset would fit without rubbing. I would like to put a set of wheels on my moms RX and am having a hard time finding information since I am not a regular Lexus forum members.
Thanks in Advance
-Nick
Thanks in Advance
-Nick
Use tirerack.com.
Or go to classifieds and approved vendors list.
You should post in the classifieds. Good luck.
I don't need classifieds, I was wondering if there was a wheel fitment thread. Apparently not, I understand this is a low modded vehicle. I was just curious if I install a 2" wider wheel if it would rub. I can currently get some TSW Montage wheels for about $280 a set in either 19 or 20 and would like to know if they fit before I order them. The threads I have found use only a 9" wheel and I would be installing a 9.5" wheel. Tirerack is a ripoff just for anyone wheel shopping.
-Nick
-Nick
Dude, ET35 is the STOCK SPECS, on the STOCK WHEELS.
So the 17x7 wheel has this. With this wheel there's a couple of inches clearance behind it.
BUT you have to account for the offset to be different with the new wider wheels.
I personally would get the new wheels in a ET20, since figuring in my head it would be about right in terms of clearance.
In the mean time do some reseach: http://www.rimsntires.com/specs.jsp
Plug in OEM specs, and play around with the new specs and offsets to see what will fit and what wont.
how?
as for 9.5, i dont think anyone has ever put that wide a rim on a rx. weither it'll fit or not? probably, you'll just have to be a guinea pig to test out the offsets.as for a 9" wide rim, i believe et20 will get it flushed with fender
Valeno, I did see your thread and was looking for exact match, I read the 22" in the other thread and the offset, both of which were different from the wheels I was looking at...
