Mityvac Transmission Fluid
Old 07-07-10, 09:51 AM
968racer
968racer's Avatar
Default Mityvac Transmission Fluid
Has anyone used a Mityvac to suck out the transmission fluid though the dip stick? Can this be done & if so, how much fluid can be extracted? I don't own one but would probably get one if it could be used for this.
Old 07-07-10, 10:17 AM
lexus114
lexus114's Avatar
Actually they work pretty well. But honestly,i`ts easier to do a drain and fill than an oil change on the RX.
Old 07-07-10, 11:04 AM
mandyfig
mandyfig's Avatar
Should work and work well. But the drain and refill is all you need.
Old 07-07-10, 05:46 PM
salimshah
salimshah's Avatar
Received 1,081 Likes on 973 Posts
I would not do that.
The drain is done at 2 places while the suction is done at 1.
Drain from below is better to get all sedimentation out.
As Lexus114 says ... Transmission drain on RX is much easier than engine oil change. It is not that you are reducing the work by much.
Salim
jiodaqmke
20
07-19-11 03:30 PM
OutlawTita
Maintenance
04-16-10 01:38 PM
Jubane
RX - 1st Gen (1999-2003)
16
06-05-06 10:25 AM
Bobk528
16
09-26-05 07:34 PM
lowlowlex
03-03-04 10:14 PM
Quick Reply: Mityvac Transmission Fluid
