Help with my Water
I am trying to take out about 1/2 qt of anti freeze from my cooling system so I can add an additive. I can't figure out how to get it out without taking off the lower hose.
It is filled right to the top & I can't get any kind of hose down the filler.
HELP
HELP
There is a plastic drain plug at the bottom of the radiator. You should see rubber/plastic tube sticking down through the splash shield ... just trace it straight up. I had to apply quite a bit of force. The good thing about the plastic drain plug is that you can twist it shut at any time.
The other point is a drain bolt near the oil filter.
Check out the DIY on coolant flush.
Salim
Salim
gtstcactus
04-02-14 06:32 AM
