TSB ECU upgrade for transmission
Hello,
I've got an appointment scheduled to get my ECU flashed. I have 129000km on my RX. I remember some people have been able to claim it under warranty. May I get some advice.
Thanks
Thanks
I had my 04 RX 330 AWD flashed and found that I got better city mpg afterwards. Highway MPG was unchanged. I also changed my Goodyear OEM tires to Bridgestone Alenza's at the same time so I can't be sure which attributed to the increase in MPG. The trans lag was lessened by this flash but is still there.
I think this may be covered by Lexus. It only takes a few minutes to apply.
It would be covered under warranty. However, this late, out of warranty, and with over 80K miles I would make sure you discuss price with the dealer in advance lest you get an unexpected bill afterwards.
i asked my service dept for this tranny flash when i brought my car in to turn off the auto tilt steering wheel and they told me there wasn't one available for this car ?? should i try another dealership? wats the specific name called "tsb ecu flash" ? whats the cost to do this? straight labor?
Here is the code you are looking for:
TC005-03R ECM CALIBRATION: SHIFT FEELING ENHANCEMENTand make sure to ask them also to do TC002-03 ECM RESET MEMORY FUNCTION
So I went to Ken Shaw Lexus today for the lagging transmission. The technician looked and discovered that I have the lastest TSB 'flash' available. So the lagging shifts has not been resolved, yet still present.
The service manager stated that one option available is to reset the ECU and go from there. Yet his experience is that resetting the ECU is a 50/50 gamble, either the problem get worse or it resolves itself. I think one of the other problems is that there is 2 drivers- my wife and myself.
Any thoughts as I'm interested.
Thanks in advance,
Chris
Thanks in advance,
Chris
The buyers have a bit of leeway on milage. Ask nicely first and most probably Lexus would comply.
The odos are never accurate and specially when the milage is based on number of turns of the wheel, which registers more miles than the actual distance traveled as the tires wear out. [poor wording, but you get the picture]
So ask first.
Salim
So ask first.
Salim
why would it get worse ? From all the searching and research I have found so far -its a software issue. the 04-06 supposely have it worse than the 07-09 its a bit less noticeable - right ?
ecu, is300, lexus, options, reflashing, reset, rs, rx, tc00503r, toyota, tranny, transmission, tsb, tsbtc00503r, upgrade
