A question on ML system
Excuse the noobishness. I have a non ML system in my RX. I like the factory look and dont want to upgrade to one of the aftermarket systems as they ruin the aesthetic appearance. I like the V shape and the aftermarket doesnt have a headunit that follows that V contour. If you are still with me read below![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I wonder what it would take to upgrade to the ML system. Is it a big upgrade over the premium system? I am an audiophile but I dont want to start spending on an aftermarket system as I wont be able to stop and I dont want to spend anymore than I have to lol.
Is it a viable option? Is the RX prewired for the ML or will it be an ordeal to do?
let's see 8 vs 11 speakers? Is it worth adding 3 speakers? Some folks aren't impressed by the ML system. There are DIN faceplates that allow you to add aftermarket stereo systems and maintain the factory finish.
Really. I didnt know about din faceplates thing. Im mostly into home stereo stuff. Not as versed on the car audio stuff. As for it being worth adding 3 factory guaranteed fit without spacers speakers then I thought it would have been cheaper than a full aftermarket setup. Ive never heard the ML system in an RX for a prolonged listen so I dont know if its worth it acoustically. Thanks for your imput. I will take your advice and look into the DIN faceplate.
The ML system in my RX400h is OK, but nothing to write home about. It's definitely laking in bass, which is something others have complained about. Classical music sounds great on it, but anything bass oriented - not so much.
You could always change the door speakers and make a dramatic change. 6x9 up front and 6 1/2 in the back. You'll have to make custom brackets for the speakers; the factory ones have plastic forms to bolt on. Not hard at all, I installed all Alpine and used wood for the brackets; thought wood would be better acoustically and vibration dampening. They made a dramatic difference and after handling the factory speakers you'll know why. I also installed a Alpine Nav head unit.
Here's what you want to know about:
http://beatsonicusa.com/stereo/stere...-350-400h.html
http://cgi.ebay.com/ebaymotors/JDM-L...Q5fAccessories
I had a loaner that didn't have the ML and it doesn't compare at all, not even close IMO. I have the ML and I think it sounds much better than the non ML version.
With that said, would I upgrade to the ML if I had a non ML system? My answer would be no. I can get even better sound going aftermarket with fewer speakers and careful speaker placement. It's not always about having the most expensive gear but rather getting a good install/placement of them. However, getting "better" gear never hurt anyone except your pockets!
No, I don't play soccer!
I changed out the speakers and added kick panels, amps, subwoofers, clean sweep and soundlinq in my non-ML '04. Most of the stuff was hidden under the cargo area. It made for a clean install. I kept the stereo since it was integrated with nav/climate control.
I can definitely understand the 'don't know when to stop' part. All I wanted to do was get better speakers
I have ML now in my 450h. Fortunately it's decent enough for me not to go crazy again. Good luck.
I don't know how bad/good is standard system, but ML isn't that good. My RX350 has ML system and I'm not impressed.
When compared to other 2 cars I had before (both cars had upgraded audio systems), ML is terrible. One of cars had upgraded Harman Kardon audio, and another one had "non-branded" system with VW logos (the car was VW Phaeton W12). Both of them were so much better than ML, so I don't think you should upgrade.
Wow.. Thanks for all your opinions and the links. I will get cracking on this soon as i get some time. I will definately go aftermarket now. I like the wood bracket idea. I guess I can take a plastic bracket to a wood shop and have them make a replica in wood. Again thanks for the ideas.
Making the bracket is easy if you have a jig saw and easier than you think. Take a piece of paper and cut a hole in the middle to fit mount side of the factory speaker. Drop the speaker in and out line the bracket plus blot holes. Cut the outline and now you have a template for two doors (one 6 1/2 and one 6x9). Your after market speakers will have a template for the speaker cut out. Mount the speaker and use clued THICK foam to make a surround to fill the door gap between the speaker and the door trim, this will also cut road noise and channel the beats :-)
I have pics I can post later, if you are interested.
Oh please do post pics if you can. I'd really appreciate it. I could probably pick up a jigsaw to do this.
