Air Filter A DIY Job?
Old 03-25-12, 09:59 PM
RX330inFL
RX330inFL's Avatar
Originally Posted by RuninRoach
cabin filter change takes 30 seconds....No i'm not kidding. 30 seconds.
lemme know if you need a video and i'll throw one together soon. Also, which air filter is the best for city environments? I would get a K&N but in hong kong those things would be hard to maintain. I would much rather get disposable and keep changing every 3 - 4 months (yes, its filthy here).
You are replying to a two year old question, RuninRoach, and not the question posed in the previous post by uscmas412 who is concerned about the fit of the air box after he replaced the engine air filter.
Old 03-26-12, 01:26 AM
RuninRoach
RuninRoach's Avatar
whoops...my bad.
Old 03-26-12, 01:59 AM
RX330inFL
RX330inFL's Avatar
Originally Posted by uscmas412
I figured I would post this here rather than creating a new thread. I just installed a new engine air filter, but the left side of the filter box does not seem flush. You can see in one of the pictures below the white plastic filter housing. The right side of the box seems aligned perfectly. Thoughts?
It should fit flush. You will need to loosen everything back up again and try to get them aligned. With the lid lifted a bit it should go together. Rock it back-and-forth as needed. Force may be required but remember these are plastic parts.
Old 03-26-12, 05:14 AM
ycl1688
ycl1688's Avatar
By uscmas412 at 2012-03-25
you got to keep trying to set the left side flush just like right side, first make the left side set then right side will get right. You left side does not flush not a good sign, dust will get in. Takes a little while to make it right. Would advise take a picture after job completion.
Old 04-01-12, 09:38 AM
amieex87
amieex87's Avatar
anyone have any videos? first timer...=(
Old 04-01-12, 09:47 AM
hypervish
hypervish's Avatar
Welcome to Club Lexus!
I found this video by doing a quick search on youtube:
If you need a DIY for the cabin air filter, here's a link: https://www.clublexus.com/forums/rx-...ent-rx350.html
Old 05-02-12, 07:32 PM
mrmike490
mrmike490's Avatar
I've used K & N for many years on my Lexus(es) and Toyota(s)......AND I live in the country so that definitely says something! They are well worth the dollars spent if one abides by the changing periods (stated on the box)
Old 05-03-12, 04:23 AM
tomit
tomit's Avatar
The 2nd time I changed the air filter, I took the time to loosen the host clamp that secures the housing top to the intake so the top could be swung out more. That way it's easier to make sure that the new filter is seated properly. My 2 cents.
OH2013GS
06-25-14 06:42 AM
melbitoast
IS F (2008-2014)
17
01-17-14 05:58 PM
sunnyside
RX - 3rd Gen (2010-2015)
06-24-13 07:21 AM
SC3coupe
07-16-10 01:43 PM
TA-9ff
ES - 5th Gen (2007-2012)
11-04-09 09:24 AM
Quick Reply: Air Filter A DIY Job?
