Air Filter A DIY Job?
Old 09-22-10, 04:57 PM
daryll40
daryll40's Avatar
Default Air Filter A DIY Job?
It is easy to replace the air filter? And if so, what filter should I buy and where to get it?
I was reading the manual for my 2006 RX330 and the 30,000 service is really nothing more than the usual oil change but with brake fluid changed (done with new pads a few months ago) and an air filter change. I figured I'd buy a good filter and DIY with some help here!
Old 09-22-10, 06:40 PM
biff44
biff44's Avatar
it is wicked easy to do.
Old 09-23-10, 04:27 AM
redrocks
redrocks's Avatar
Easy, just don't lose the screws, they can fall out easily.
Old 09-23-10, 06:15 AM
mandyfig
mandyfig's Avatar
Take your time with the bolts. They are a PITA, but once you have done it, your 2nd will be a breeze.
Old 09-23-10, 06:16 AM
mandyfig
mandyfig's Avatar
My air box is jammed in there tight. It hits the bracket making it hard to lift the cover and put it back. I am sure later on they did something about it. Sure is a PITA.
Old 09-23-10, 06:45 AM
phlfly
phlfly's Avatar
Where is filter inside or outside of the cabin?
When I was changing the spark plugs, I don't remember seeing filter when I was removed wiper mechanism tray.
Edit: Sorry I got my answer use a search button.
Old 09-23-10, 09:14 AM
ycl1688
ycl1688's Avatar
Definitely a breeze to change air filter after removing the screws at the 6 & 12 o clock position, the screws should not come out, when you install the new filter, make sure the cover goes in first at the 9 0 clock position then you are in business.
Old 09-23-10, 03:37 PM
daryll40
daryll40's Avatar
I did it! Your (plural) tips made it easy! Thank you guys!
Old 09-24-10, 06:40 AM
lexus114
lexus114's Avatar
What filter did you put back in?
Old 09-24-10, 08:42 AM
daryll40
daryll40's Avatar
I installed Purolator
Old 09-24-10, 09:39 AM
lexus114
lexus114's Avatar
That should be fine.
Old 09-24-10, 04:12 PM
jmonkie76
jmonkie76's Avatar
This is a little off topic but where are the cabin air filters located?
Old 09-24-10, 04:34 PM
howdybob22
howdybob22's Avatar
Glove box. Check your manual on how to change it out.
Old 03-25-12, 07:41 PM
uscmas412
uscmas412's Avatar
Default 2004 RX330 Engine Air Filter
I figured I would post this here rather than creating a new thread. I just installed a new engine air filter, but the left side of the filter box does not seem flush. You can see in one of the pictures below the white plastic filter housing. The right side of the box seems aligned perfectly. Thoughts?
By uscmas412 at 2012-03-25
Old 03-25-12, 09:41 PM
RuninRoach
RuninRoach's Avatar
cabin filter change takes 30 seconds....No i'm not kidding. 30 seconds.
lemme know if you need a video and i'll throw one together soon. Also, which air filter is the best for city environments? I would get a K&N but in hong kong those things would be hard to maintain. I would much rather get disposable and keep changing every 3 - 4 months (yes, its filthy here).
Quick Reply: Air Filter A DIY Job?
