Broken Key Case on 2004RX
Old 09-29-10, 07:55 AM
Fivewilds
Fivewilds's Avatar
Default Broken Key Case on 2004RX
I broke the case on my key. If I hold it together all the buttons still work. Can one buy just the case and is this a DIY type of fix?
Old 09-29-10, 08:05 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
How well you do get along with your dealer? They replaced my broken case last year, no charge, about six months before I traded in the '04. It doesn't hurt to ask.
Old 09-29-10, 09:22 AM
mandyfig
mandyfig's Avatar
Ebay has plenty of them.
Old 09-29-10, 09:59 AM
Jonrx350
Jonrx350's Avatar
buy new case with key already cut, then switch the electronic. Good luck switch the key blade. I bought from STEVE ( lexusofnorthmiami ) on fleabay like THIS_ONE. He usually ship the item out couple hours after I place my order.
Old 09-29-10, 11:36 AM
salimshah
salimshah's Avatar
Received 1,045 Likes on 943 Posts
Which Part broke .. the 1/2 cover or the other half with the key molded in?
If it is the cover, just visit your dealer parts and they may be able to give you one from the cannibalized tray. For the other you will need to buy a Key (ebay or dealer or web)
Salim
Old 09-29-10, 01:28 PM
Fivewilds
Fivewilds's Avatar
Salim
Both sides broke. It broke off right where the little screw holds it together. I took it apart and see that the key is sort'a molded in the plastic. Guess I'll have to order one on e-bay and have a locksmith cut the key.
Old 09-29-10, 01:43 PM
ktranne
ktranne's Avatar
I bought a cut key from the guy on Jonrx350's post. It came pretty quick.
Old 09-29-10, 01:49 PM
mandyfig
mandyfig's Avatar
Suggest to buy 2. Spare will be handy.
Old 09-29-10, 02:55 PM
offroad200
offroad200's Avatar
Salim
Depending on the model, we (a dealer) can actually order just the back now. It's about $3.50. We keep some it stock, so your local dealer may too.
Old 09-30-10, 09:38 PM
JoeInHNL
JoeInHNL's Avatar
I just bought keys from this guy:
http://myworld.ebay.com/ebaymotors/1010keys/
2 for $40 including shipping. Got them in a few days. Look good, work fine.
Old 09-30-10, 09:56 PM
RX330inFL
RX330inFL's Avatar
One good reason why Lexus went to keyless ignitions, IMHO. They couldn't make a key that would hold together. Believe I have broken 3 so far for my RX330.
JoeInHNL, went ahead and bookmarked that seller in eBay... just in case. Thanks.
Old 10-01-10, 09:41 AM
ycl1688
ycl1688's Avatar
I got the keys from the same person real good stuff. my question is what it takes to program the remote ?
Old 10-01-10, 09:53 AM
mandyfig
mandyfig's Avatar
$40 for 2, $20 a piece with cutting is reasonable. Actual cost to mold the key, $ 2.00 tops. But with it pre-cut, can not beat it!
This is a good investment.
Old 10-01-10, 12:49 PM
RX330inFL
RX330inFL's Avatar
These do not come with the electronics. You just remove them from the old, broken, one and put into the new shell. Thus, no programming required.
If you want extra keys, you will need to also purchase the internals as well from another source.
Old 10-01-10, 02:15 PM
LEXEHAM
LEXEHAM's Avatar
I lost a master key and bought a replacement one from Sewell, I gave them the vin so they could cut the key. The key arrived today and it is not cut correctly, it doesn't fit into the ignition. I am in the process of returning it to Sewell. Has this ever happened to anyone else. The car has never had a lock cylinder change. I was planning on going to go to my local dealer for the programming, they said they would charge $65.
Quick Reply: Broken Key Case on 2004RX
