Thinking about buying a Lexus RX330 from a little old lady
#31
OTOH, I had a mechanical failure and the Lexus dealer set me up in an office with a secretary to assist me in putting together a presentation I needed to deliver by 5PM that same day. They went the extra mile, even providing me lunch while I waited and I certainly appreciated it. Everything in life comes with a cost. Sometimes the cost is a value other times it is not.
The actual physical things called for aside from all the inspections:
•Brake fluid is replaced at 30k and 60k [Every 24 months]
•ATF, Transfercase and differential(s) fluids are replaced if you are towing, otherwise just inspected. [Every 12 or 24 months] (FWIW, I'd recommend replacement.)
•AC Filter replacement [Every 6 months]
•Tire Rotation [Every 6 months]
If you register at Lexus.com I believe you can access the owners manual on-line. Search for the maintenance supplements. You can bring that maintenance schedule to any Toyota or independent and get an estimate.
pearl93'ls
08-22-18 01:04 PM
