2005 RX 330 Trailer Wiring
I found the wiring behind a rubber plug on the rear left underside. It looks like the white plug is taped or connected in some way to another harness.Is there another harness you have to get to connect to the white plug ?How hard is it to get the wiring dropped so you can get at it ?When you connect to this plug do you come out that same hole thru the rubber plug ?Thanks
if you buy the hitch from the dealer, it comes with the OEM wiring, that is what that plug is for.
if yu go after market and save hundreds, then you can still use that white plug, you just need to cut it off and splice into those wires. and yes you will need a converter box so you dont damage your electrical system. hardest part is running a wire from the battery to the trunk.
this topic has been covered mulitple times try a search for more info
