45k miles service
I'm not sure what year your's is. I'm going to take my RX330 in for the master brake recall. Typically for the 60K, they drain/change brake fluid, oil/filter, cabin filter, check brakes, fluids, and the cost is around $450.
They will change the brake fluid when they do the recall, I can change the filters, so I'll probably have them change the oil and look everything over. It'll probably cost $100 at the Lexus dealer.
I took it to Toyota for the oil change. I'd see what is included in the 45K mile service, it is probably mostly checks and inspections along with and oil change, cabin and air filter change, and they'll probably want like $250. Change the filters yourself and get an oil change. I don't know what they'll charge you for the the other "checks and inspections."
Keep us up to date!
Keep us up to date!
The lexus service manual has the following:
Change oil and filter and Inspect all other fluids
Rotate tires
Clean air conditioner filter
Inspect rotors and brakes
This is considered minor service. I take mine to the Toyota dealer for this. The cost is about $60. At Lexus expect about $150
Rotate tires
let me point out that if you go in and ask for any of the "services" you will pay a whole lot more than if you take it in and specify what you want done. What you want done can be determined from your service manual. A typical "service is in the $170 range if I recall. Simply asking for an oil change is about $50. When it is time for other items such as transmission oil change, differential change etc. just add these items to the list and you will save significant dollars over the life of your vehicle. Some of the major services that include these items can reach $750 or so.
I have also ways taken my RX330 to the Toyota store .It is < $500 here for the new timing belt , oil and tires sevice < $65 and that is for Mobile 1 , transmission drain and fill < $90 ,Brake fluid change was < $80 . I order the air filters and blades for the wipers <$70 online and change them out myself.
zmoneyJD
04-10-17 02:07 PM
