RX 330 Mirrors
Old 12-09-10 | 07:45 AM
rstrong's Avatar
rstrong
Default RX 330 Mirrors
We had to put a new battery in the 2004 RX. Now the mirrors don't angle down when the car is in reverse. Any suggestions?
Thanks
Old 12-09-10 | 07:54 AM
lexus114's Avatar
lexus114
Hmmmm....thats odd. I know in the manual it will tell you how to reset the power window`s etc. but I dont know if it will tell you anything about the mirror`s. Try disconnecting the battery again for a few minutes,and see if that clears it up. Also make sure the mirror switch is not in the middle position,if it is,they wont tilt down.
Old 12-09-10 | 08:38 AM
rstrong's Avatar
rstrong
Thanks. We'll try that. I'll let you know how it comes out.
Old 12-09-10 | 09:30 AM
lexus114's Avatar
lexus114
I`ll be here.
Old 12-09-10 | 10:16 AM
willyb0b's Avatar
willyb0b
do you have the mirror switch either in the left or right position?
the mirrors will not angle down in reverse if the switch is in the middle
Old 12-09-10 | 11:59 AM
lexus114's Avatar
lexus114
Dude, I mentioned that already. "Also make sure the mirror switch is not in the middle position,if it is,they wont tilt down."
Old 12-09-10 | 01:38 PM
willyb0b's Avatar
willyb0b
yes, you did
Old 12-11-10 | 10:38 AM
rstrong's Avatar
rstrong
Tried both suggestions. Still no angle down when in reverse.
Thanks for the tips though.
Old 12-11-10 | 10:49 AM
mandyfig's Avatar
mandyfig
Maybe check the fuse? Does it go sideways?
Old 12-11-10 | 06:20 PM
Poqman's Avatar
Poqman
If it goes up/down manually, then it's not the gear drive or motors. Try manually running the mirror all the way down and then all the way up and then back to the normal position. This once helped mine.
dvdmull
NX - 1st Gen (2015-2021)
19
03-09-18 01:05 PM
NUAE
10-27-13 03:43 AM
SeanGTS
IS F (2008-2014)
11-09-11 07:09 AM
UZ214
07-14-09 02:49 PM
jcboiz
01-14-06 05:03 PM
