Faulty LED light
The "Tire Inflation" light is on and does not go off even after the local mechanic inflated the tires with the correct pressure. Anyone know what to do without going back to Lexus?
Take it for a spin and let us kow if it settles down. What year is your 330? The 04's had a different method of the TPMS than the 05 and up (I think).
can it be the spare?
Salim
Salim
The 2004 RX doesn't actually monitor the tire pressure. Instead, it looks at the rotation speed of the wheels. If it senses a wheel spinning faster than the rest it thinks you have low tire pressure. If all four tires have the same pressure and you have not changed the tire sizes then you probably have a sensor problem and Lexus will need to replace it.
Yes, I am Willie330. I have used this ID for the last 10 years and have many websites that accept this in order for me to enter. I don't even know the reason I picked the number(have never had a Lexus before this year- a 2009 RX350). Have been a Jeep Grand Cherokee owner in the past. Just to many websites with that ID to change now.
Thanks for the responses to my predicament. Seems like alot of Lexus owners have the same problem. With all tires(including spare) at the correct pressure it appears that I will either ride with the light for awhile or go to the Lexus dealer. Again, if anyone has another suggestion, let me know!!
Registered User
Willie
Have you reset the Tire Pressure System? My spare throws the light on about every 5000 milies.
You can have all of the tires set to the correct pressure. And the light will continue to stay on. Untill you reset the system.
Go to your owners manual. It shows how to reset the system.
Or do a search on this web page.
I have read the threads about resetting the system including buttons in or around the glove compartment and the steering column. I have not been able to find anything about that in my manual! Again I have a 2009 RX 350 which is not the same as some of the older models. If I am missing something let me know. Thanks.
