gas question
Old 01-19-11, 11:12 AM
RX330inFL
RX330inFL's Avatar
Originally Posted by adam8065
Should I be using Chevron fuel cleaner every 3,000 miles, 4,000 miles or etc?
As you are running premium fuel -- I would say no, it is not necessary. If you were running regular I would probably say yes as there are usually less detergents in the lower octane fuels.
I treat my RX to a bottle of Techron once a year.
Old 01-19-11, 10:51 PM
MrBruin09
MrBruin09's Avatar
So just to reiterate; as long as I run any premium gasoline, from any gas station, a bottle of Techron once per year is sufficient?
Old 01-20-11, 07:13 AM
lexus114
lexus114's Avatar
Originally Posted by ripster
Premium only hurts at the pump, after that its the cost of a candy bar as I fill up at 3/4 tank most of the time. The engine really needs it with the compression ratio.
It`s only about a $4.00 difference between reg.and prem. fuel per tank.
Old 01-20-11, 07:52 AM
dewalt
dewalt's Avatar
As my father always tells me....own a premium car, stop *****in about premium gas.
I always got worse mileage on regular gas in every car I've owned that required premium. It works out to nearly the same cost. You might as well put premium in there.
Old 01-20-11, 09:43 AM
lexus114
lexus114's Avatar
Plus it will run as designed.
Old 01-20-11, 11:40 AM
VAttorney
VAttorney's Avatar
So is the RX meant to have premium? The owners manual says regular and then says premium if you want optimum performance? So, okay I realize that optimum is optimum but is that the same as "run as designed". It just seems like needless obfuscation to me.
Old 01-20-11, 01:40 PM
Rainbird
Rainbird's Avatar
Premium fuel is required for the Lexus RX350 because of the higher compression ratio. Your 2004 RX330 will run fine with regular.
Old 01-20-11, 01:49 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Regular is what is recommended for the '04 like Rainbird said. I went midgrade most of the time. Test out a few tanks when it's warmer to see which grade is better for yours.
Old 01-20-11, 04:37 PM
mandyfig
mandyfig's Avatar
87 Octane and fuel cleaners every 4~5K miles. Working like a charm.
Old 01-21-11, 05:22 PM
jgr7
jgr7's Avatar
Premium, Costco, Sams or Arco/BP, no cleaner no problems 47K.
Jeff
Old 01-22-11, 08:24 AM
RX330inFL
RX330inFL's Avatar
The bottle of Techron is optional. No scientific foundation one way or the other. More an item to make one feel good about one's actions. I do it as my RX does not always get a chance to see time on the highway to get a good run and blow out any carbon.
Old 01-22-11, 01:10 PM
lexus114
lexus114's Avatar
you guy`s man,Just run what is recommended which is 91 or higher. Yeah it`l run on 87,but that`s about it. Dont expect any real performance from it then either. I.E passing power,pulling hill`s with the A/C on in the summer time,etc.
Old 01-22-11, 02:13 PM
jfelbab
jfelbab's Avatar
I've been using Shell V-Power for years and haven't needed any injector cleaner. I do get 1.5-2 MPG more on the expressway when running premium in my RX330.
Old 01-23-11, 11:06 AM
lexus114
lexus114's Avatar
the Lexus is a premium vehicle, yet people dont want to to the same re; the fuel to keep it running like it should. Years down the road skimping out on the fuel may come out to bite them.
Old 01-23-11, 11:09 AM
mandyfig
mandyfig's Avatar
Premium really works better with our cars.
Quick Reply: gas question
