Rear Passenger Window Air Buffeting Issue
Old 02-06-11, 09:09 AM
Bobs850
Bobs850's Avatar
Question Rear Passenger Window Air Buffeting Issue
If you drive at about 55 mph with the rear passener window down and all the other windows up, the wind buffeting inside the car will actually hurt your ears and your head. Things are ok up to about 45 mph. At any speed over that, the buffeting inside the car is really bad. It is my wifes car. This is our third RX and we have had it since December of 2008. I seldom drive the car. This did not become an issue until we got a dog.
Anybody else faced this problem?
Thanks,
Bob in Fresno
Old 02-06-11, 09:31 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,260 Likes on 1,373 Posts
Bob, that 'helicoptering' issue happens in about every new car and in every Lexus I've owned (not specific to the RX). The simple solution is to crack another window in the car, even the opposite rear window.
Examples:
https://www.clublexus.com/forums/ls4...fra-sound.html
https://www.clublexus.com/forums/gx-...ndow-down.html
Good explanatory post from thread above
Originally Posted by The G Man
The Helicopter noise is cause by the Bernoulli principle. It is pretty common in newer, more areodynamic cars.
A car at speed will cause an air stream, more so at the side rear window. That air stream creates a low pressure zone where it will draw the air from inside the car to the outside air stream. As more and more air is being drawn out, at some point the air pressure inside the car actually becomes lower than the outside air pressure and a rush of air enters the car. This cycle repeats itself and the air moving in and out of the car is what cause the helicopter noise that you hear.
https://www.clublexus.com/forums/rx-...icopter+window
Old 02-06-11, 10:13 AM
redrocks
redrocks's Avatar
It's normal.
Old 02-06-11, 01:21 PM
Bobs850
Bobs850's Avatar
Thanks. At my next service I am going to have them fix the rear drivers side window that has never worked with the drivers side control buttuns. For the time being I will roll both back windows down before I take off. That should keep both my ears and the dog happy.
Old 02-10-11, 10:50 AM
mandyfig
mandyfig's Avatar
Yup learned that way early on. Air dynamics.
Old 02-10-11, 11:41 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I usually open one in front and one in back....
RXSF
RX - 3rd Gen (2010-2015)
12-07-11 11:13 AM
stevemcb
05-06-09 05:47 PM
six30two
12-27-08 08:17 PM
Luke_in_SD
SC- 1st Gen (1992-2000)
16
10-31-07 10:09 AM
RufRidn
07-05-07 08:42 PM
Quick Reply: Rear Passenger Window Air Buffeting Issue
