Front Number Plate Holder
eyezack that is a very handy idea. Next thing I have to figure out is how to get the plate screwed to the bumper without falling over and then I'm set. If you'll notice in the first picture of the close up of where the plate is mounted, the upper middle holes actually have a thread clip that sits in the actual holder. The threadclip is to big to fit in the actual holes that the plate holder leaves. I have to find a solution to how to mount the plate now.
Good idea on the temp bumper hole plug!
http://www.amazon.com/Cruiser-Access.../dp/B00032K4TW
and I got some bolts/washers so I can move it up/down the track as well as from side to side. My idea is to mount it so it hides the middle and just use the bumper plugs for the outer most holes. The bracket by itself doesn't look half bad if I'm honest but this could be a viable option for you
Yeah, its one of those things you find "OEM" online for a crazy price but its rather easy to do haha
eyezack have you got a picture of the bracket installed and also what the dimensions for it are? I would like to see what the measurements are when applied to the measurements of the holes that are in the bumper.
Completely agree with the hole plugs. That is a great idea.
As for the dimensions, I'll have to grab those for you sometime this weekend since I'm guessing you want me to measure the distance between the mounting holes. Its midterms week for me
Thanks for the pic eyezak. The distance measured between the mounting holes would be great. Not sure how this would compare with an RX though. Incidentally very nice clean looking Camry you have there.
I have had an idea after doing some research in some various forums last night, that might be able to let me get away with out purchasing a frame.
Thanks! I'm a hobby/professional detailer
I had some time to play with this on the weekend and designed a very simple bracket to hopefully replace the "fugly" license plate holder that the Australia delivered RX's recieved. This would of course all hinge on how well the bumper has held up underneath the holder.
Removed the license plate holder and gave the area a quick wash down with some car wash and water. Amazingly it came out quick nice. No sign of the scratches from earlier in the post (and if they are there, not noticable at all). There is a slight outline of where it used to sit, but I think a polish should pretty much get rid of that.
So with this proving to be very clean, I went ahead and constructed my bracket for my license plate. Given that I did not want to have the license plate protruding too far out from the bumper, I tried to build it as close as I could to the bumper. Given that the type of brack I envisaged was not something available in the hardware store, I bought the following components (no more than $7).
5 * Galvanised Flat Make-Your-Own-Bracket 20 * 200mm (these you can split into numerous brackets and make you own shapes).
1 * packet of 4mm Bolts
1 * packet of 4mm nuts
After playing with the idea for a while, I realised that the brackets themselves and the holes on the license plate were not going to necessarily fit where I needed to. So I extended the bracket on the right hand side to use the end screw point of the license plate (rather than the centre hole). One part of the license plate is screwed on to 1 centre hole, the other at the end of the license plate. Hopefully the following will illustrate what I am trying to say.
Here you can see the centre screw for the left side of the license plate, and the screw on the far right for that side of the license plate.
Now I know that the metal behind the plate can be seen just peaking out, but I did last week buy a license plate cover and installed this over the top and pretty much it hides everything.
So here are some pictures of my RX with my new license plate holder. Took it for a drive over bumps and general driving and it is all stable.
All I have left to do now is come up with a solution for those 2 small holes that have been left over. I did have a look at the hardware store, and couldn't find anything yet that will fit these holes.
The car looks so much cleaner with that factory fugly bracket and I am glad that I did this "mod".
Thanks eyezack. I haven't given up looking just yet. I will hunt around for something to fill the gap. I do have some spare paint lying around somewhere that I will be able to paint the plugs with to blend in with the rest of the bumper.
Hypebeast
CT 200h Model (2011-2017)
05-15-14 06:17 PM
