Offset for 8 or 9 inches
I realised that my car (2004 RX330) had the factory alloys and that they were 17 inch wheels. However I was under the impression that they may have been 7 inches wide, but to my dismay discovered that they are actually only 6 inches wide. The shock / horror of this realisation made me, well
I am now going to put a plan in place to eventually get these wheels upgraded to something with a bit more of a foot print. I am thinking 8 inches (most likely) and would like to go 9's, but I figure that will come down the cost between the 2.
I had a look at the wheels and realise that they are very close to the actual strut, not really leaving that much room. I suspect this is where the offset comes in to allow the wheel to be pushed out a bit further from the hub (not very good with the term or how it works). I live in Australia, so it is illegal to get hub extenders or anything like that.
What sort of offset would I need for 8 inch or even 9 inch wheel widths. These scrawny tyres are getting to me as they are so anaemic.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
How about the 5 spoke upgrades that we have here? They are 18's. And if you select the Alenza's they are bigger in footprint compared to other 18's.
I have seen probably 1 RX330 with the standard 17's around here. Not many realize that 17" is the standard for the RX.
Hey Mandyfig, I have looked at the 5-spoke 18" wheels that came stock on the RX350's (and the late 2005 330's) although I believe they are still only 7" inch in width. I'm thinking it may need to be a custom wheel, that looks similar to the factory wheel but with a width of 8 inches. However to do that I do need to know what offset I can use to fit 8 or 9's.
Looks like I would need to use an offset of anything between +30 and +35 (the stocks are +50) to fit 8" inch wheels or 8.5" rims (depending on dish).
http://www.streetdreams.org/wheel-fi...ortby=&start=0
My dad runs an 18x8 set with an ET 35, no clearance problems with the 235/55R18 tire as per OEM specs. Mind you there's about 5mm of clearance between the rear strut and tire, but it fits as it should.
![](http://i582.photobucket.com/albums/ss263/errorseller/Detailed%20RX330%20-%202004/IMG_3508.jpg)
You can do 8 inch width no problem with 18' rims. If you want 19 or 20's, you will have to make sure you don't run into clearance and handling issues.
tarponman
09-30-09 07:03 AM
