04 rx330 headlight TSB info
I would like to get a copy of the TSB re the defective headlights, which might be related to condensation in the headlight. If I can't get the actual TSB does someone have the number of it?
Thank you.
Thank you.
Search here: http://www.aboutautomobile.com/TSB/2...X330/Headlight
2004 Lexus RX330 Headlight TSBs
TSB Number: 00307 NHTSA Number: 10021708 TSB Date: May 18, 2007 Date Added to File: June 15, 2007
Failing Component:
Exterior Lighting:Headlights
Summary:
Headlamp condensation.
Failing Component:
Summary:
i keep getting water leaking inside from somewhere on my 2004 rx330 but its only on the right side.... i have seen others on the road with the same issue (only right side??) i have taken the headlamp assembly out and resealed it and even went to the point of siliconing it still leaks from somewhere??? WTF?? takes for ever to dry the headlight out... the TSB says something about 05-06 models??? is the 04 covered as well or am I just not reading it correctly...
This like takes ya to the a listing of the TSB, but does not say anymore about it. I'm looking for the detail "the content" of the TSB as in how does it read. Anyone have this info they can post?
Search for the DIY on the headlamp condensation, I think I posted the TSB there.
It doesn’t matter if the car has new car warranty or CPO. The dealer is NOT obligated to replace the headlights since they’re only TSB item. If you call Lexus HQ, they’ll offer to pay for the headlights but you’re responsible for the labor.
romegene
06-26-11 03:07 PM
