08 RX 350 - Rear Brake Pads
Thanks Adam and Billy. Is it really necessary to have the rotors resurfaced at the same time, or can I simply have an independent mechanic slap on Toyota OEM pads that I can get cheap (about $45) online? Local Lexus store wants about $370 for the rear pad replace service (includes resurfacing rotors, etc...)
Alternatively, can I have this done at a Toyota store? Or should I simply not mess with this nickel and dime stuff, and simply bite the bullet at the Lexus store. That way, at least I'll have the peace of mind that it was done right?
I'm all ears....
I'm all ears....
You need to have them resurfaced every time you change pads. Even though the rotors may feel smooth, they are full of grooves that match the old pads. When you change out the pads without resurfacing the rotors, the new pads will only come in contact with the top of the grooves providing only about 30-50% of the braking capability. When you resurface the rotors, the pads now have a completely flat surface to provide 100% of the braking capability. Over time, matching grooves in the rotor and pads will develop. Since they match, they maintain 100% contact and maintain the same level of breaking.
Thanks dude. That was sort of my understanding as well. I was just hoping to maybe get by without, but no dice. I guess I'll just bite the bullet and do it the correct way. I'll be a poor man now.
unless your rotors show and feel rough, just slap pads on.
Does not take long to get the rotors re-surfaced. When done at the right time, the rotors can last 100K miles.
I would assume 2 sets of pads and 2 resurfacing will cover 100,000 miles. As long as the resurfacing did not take away a lot of meat. Hence if done at the right timing, you can extend your rotors' life.
All depending on the type of driving...hard driving means more frequent and hard stops. In that case, probably will require changing the rotors and 3 sets of pads for 100K miles.
Or take it to Toyota dealer, you will never be wrong. Get some money saved.
I had both the front and the back done at my Toyota dealer for $400 and the other good brake shop was going to be $350 and told me there would be some noise after the work was done. After the Toyota job just like new no noise and everything work fine.
Thanks Billy. I'll give my local Toyota store a ring.
By the way, does anyone happen to know in which country the Toyota OEM rear brake pads are manufactured? Part number 04466-48060. Perhaps if someone has a set, could they possibly read the country of origin off of the label on the box? "Made in ..."
Thanks in advance. If no one knows, I can just as easily call or go to a Lexus store. I'm just wondering.
Would it be better to purchase the brakes and rotors at the dealer or online after market store? Could anyone recommend a place and what brand?
Thanks jn advance
Thanks jn advance
