2009 Rx350 died
Hello, I hope someone here can tell me what is wrong with my 2009 RX350. I cannot ignite the car, and it even did not have ignition sound when I started. Is it merely a battery problem, or something else more serious?
Any comments would be appreciated.
Since you have a 2009 it would still be under warranty. You should call Lexus Roadside Assistance and they will dispatch a Lexus Roadside Tech or tow truck. Their response time is usually within an hour.
Make full use of the warranty.
It would help us to help you, if you state your problem a bit easier to understand.
Fails to ignite -> are you saying the starter turns the engine and by the sound of it, the engine is being spun are reasonable rate and the engine fails to catch?
If so try holding down the throttle near half way. If it works then there is idle control problem
There may be engine immobilizer acting up. Try another key or make sure there are not other keys in the key ring.
Salim
Salim
Call Lexus Concierge. They will take care of your RX.
