Coastal Tech Nav bypass issues
Hey guys, I just bought Lockpick3 Basic from Coastal ETech and it is supposed to remove 'I agree' and free up destination screen while in motion. I agree prompt has been removed now. However, destination still freezes up while moving. Instruction says to push destination button then the red pin on left upper corner, but nothing happens.
I would appreciate any info from anyone with exeprience with this matter.
The latest version (10.1) of the Lexus Navigation Disc does not require you to press the "I Agree" screen. It does not however allow you to input info while moving. They have Discs for Generation 4 or 5 Navigation Systems.
Gen 4 discs do not remove the nag screen regardless of the version. Gen 5 started the nag removal at version 7.1. That is why I was interested in the model year, gen 4 needs the LP1 not 3. If it is a gen 5 the issue may be an old nav version, say 5.1.
08'. It is fixed. Thanks for the feedbacks. Coastal tech instruction wasn't clear enough. It just said push the red pin on left upper corner, but it didn't make any beep sound as I expected, so I pushed it WHILE DRIVING when the destination is grayed out, then I pushed the red pin (still doesn;t beep), and destination screen came back functional.
