Has anyone had a timing belt break?
Old 07-11-11, 06:13 PM
cdnewton
cdnewton's Avatar
Originally Posted by emedic2327
The timing belt for the RX 330 does no damage to the engine. Thus according to my mechanic at the dealership... owned by my cousin...
Was this a Lexus dealership?
Old 07-11-11, 06:48 PM
RX330inFL
RX330inFL's Avatar
Originally Posted by cdnewton
I don't know where it is listed as "non-inteference" unless you are looking at the Gates site.
Yes, Gates. Guess they have it wrong. Seems that the 3MZ-FE VVT-i is interference while the 3MZ-FE (non-VVT-i) is not. Surprising no one has corrected this mistake.
Saw your posts on the other forum.
FWIW, the timing belt taken off my sister's 2006 was pristine at 90K. Still, best to follow the recommendations.
Old 07-13-11, 06:23 PM
bsjones35
bsjones35's Avatar
I applaud you for taking such care of your RX330. But I think you will be good for a while on getting the timing belt done. I have owned (3) Lexus vehicles over the last few years and have loved all 3. I always got the timing belt and water pump changed around 100k and almost every time my mechanic said the belt still was in good shape. So I say that to say that you are in great shape at 60k. The engine in the RX330 is almost bulletproof and will last forever.
Old 07-13-11, 07:28 PM
Sandhopper
Sandhopper's Avatar
Originally Posted by bsjones35
"The engine in the RX330 is almost bulletproof and will last forever."
I am liking that statement!
Old 07-14-11, 07:05 AM
gusar
gusar's Avatar
"The timing belt for the RX 330 does no damage to the engine. Thus according to my mechanic at the dealership... owned by my cousin..."
I've got same message from Lexus mechanic as well.
Old 07-14-11, 10:05 AM
lexus114
lexus114's Avatar
My friend is a Toyota Master Diagnostic Tech/ASE Master Tech/L-1. I chatted with him to confirm. His exact quote was "it is a valve muncher and I have seen them break around 125K; I would replace around 105K with the idlers and water pump."
Also, Autodata (page 868) lists the 2004 3MZ-FE engine as an Interference Engine.
BTW, he wanted me to add, "Oh, the valves don't bend, they break, the tops fall off, lay in the cylinder and they will destroy the heads and pistons"
Cool.....
Old 07-14-11, 05:01 PM
cdnewton
cdnewton's Avatar
I understand what you are saying and that works for me. I say we chalk it up to a difference of technician's views.
Here is one he saw: "I had a 05 Highlander with the 3.3 engine, a spring broke, kicked out the shim, shim lodge and locked up the cam, cam stopped. It bent every intake valve on that entire bank ..... all Toyota engines with a rubber timing belt are not valve munchers except the 3.3 V6, 4.7V8 and the Tercel 5E used in the last gen Tercel and Paseo. .... you can take that to the bank."
As for me, I replaced ours too early (around 93K), but it was piece of mind. Next time I will wait until around 105K.
As usual, YMMV.
Old 07-15-11, 06:25 AM
lexus114
lexus114's Avatar
I`m waiting until 120,000 miles, and do the Spark plugs @ the same time.
Old 11-25-11, 06:49 PM
dave645
dave645's Avatar
Just broke down while driving due to lose timing belt tensioner. 92 k Miles 2005 RX 330. $960 to fix at Toyota, but don't know if any damage happen to the engine.
Old 11-25-11, 07:43 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
I keep reminding folks ...
Look at the bigger picture .. by postponing from 90k to 110k (pick your own number for your calculations) how many timing belt changes would you save (all number in k miles)
90, 180, 270, 360, 450
110, 220, 340, 450,
Math shows you 5 vs 4 replacements and now add reality ... would you still be owning the vehicle?
Also pay attention to the various things in the drive train.
Salim
Old 11-25-11, 07:53 PM
Emilaman
Emilaman's Avatar
I changed my belt and water pump after 110K miles, belt was almost dead. Next time i will change it after 85000 miles.
So my advice is, dont play with this belt. Change it on time, and of course take a look at it periodically. AS mentioned above broken belt is game over for engine.
Old 11-25-11, 11:15 PM
RX330inFL
RX330inFL's Avatar
I could see checking on the accessory belt periodically, however, as this discussion is about the RX330 timing belt I am a bit confused on how you expect to take a look at it periodically.
RedRover (03-21-19)
Old 11-26-11, 10:04 PM
Nick318
Nick318's Avatar
My neighbor's '04 RX 330 190K hasn't had a timing belt replacement since the day he purchased it. All i have to say is wow!!!
Old 11-28-11, 11:46 AM
gusar
gusar's Avatar
Bad idea... But good reliability science experiment... More volunteers?
Old 01-21-12, 08:41 AM
sakaike
sakaike's Avatar
Replaced our belt, idlers, water belt on an 04 RX330 at 130000 miles. While not a recommendation (we were spacing out expenses), the old belt looked practically new.
Just a data point...
Quick Reply: Has anyone had a timing belt break?
