Has anyone had a timing belt break?
#76
The bottom line: you may get lucky and not do any damage, then again, you may be in for an expensive repair.
#77
This has been posted before by moderator salimshah: Lexus Variable valve engines (i.e. the 3.3L VVTi) are interfering and depending on circumstances (relative position of piston and valves as controlled by VVTi) you may or may-not be in interference mode.
As for VVTI causing it. It's not going to happen.
#78
I'm adding to this because of a recent timing belt change: the belt looked ok, but bearings in one of the pulleys/tensioners was starting to go. That failure can still cause damage even if the belt is ok, so don't only focus on it.
#79
My original timing belt lasted 250,000 kms. Belt was shredded to half the original width, mechanic said he'd never seem anything like it.
Car is now at 280,00 and the belt has broken again.. permanent damage or dodgy install? Water pump is still original.
sarah
RX - 1st Gen (1999-2003)
28
06-23-14 12:38 AM
gslover603
02-02-07 02:55 PM
mek88
09-21-04 03:59 PM
