Doors unlock
Hi everyone,
Would like all doors to stay locked when shift to P. Followed instruction on manual but it didn't work. What did I do wrong?
Manual says to close all doors, turn key to "on", shift to "P", then hold the door lock on lock position for 5 seconds. Tried many times but it did not work.
Wil
Wil
I had this problem until someone explained that the twit who set up the programming wanted 5 seconds and only 5 seconds. Holding the button down longer fails the process.
Yes, it's absolutely ridiculous, but at least it's one of the few things you can do without the dealer...
The 5 seconds is very important. I had to start the car, shift to neutral, then turn engine off (key to aux).
Then I quickly turned key to ON postion, while very quickly shifting to park. Then I VERY quickly pushed the LOCK button down for exactly 5 seconds (the 5 beeps at the start are exactly 5 seconds). Finally it worked!
I wanted mine to NOT LOCK, while the OP wanted them TO LOCK when shifting from Park. Glad I finally figured it out.
And yes, it's very picky about being exactly five seconds.
sdwtchlvr
37
09-15-22 12:15 AM
