My Moonroof is stuck on my 2005 RX 330
Old 08-14-11, 03:09 PM
opus1492
opus1492's Avatar
Thanks for checking. I think I'm screwed.
Old 08-14-11, 03:18 PM
Carver
Carver's Avatar
Problem is you will have to drop the headliner to get to the motor and cables. Maybe there is a way to crank it from there.
Old 08-14-11, 04:10 PM
HtownBlue
HtownBlue's Avatar
Does anyone know if the closing motion is screw driven or cable driven? My guess is that it is screw driven and there is an issue with the drive screw.
Can you aid the closing or opening with you hand and see if that helps at all?
Also you may try pulling out the shade as far as it will go as that could be causing an obstruction (though unlikely).
I would also inspect the entire track very carefully. You might wind up having to remove the headliner surrounding the sun roof to fully inspect the track and operation.
ccroney
08-24-13 07:18 PM
Davegs01
08-01-13 03:29 PM
slimjimtel
RX - 3rd Gen (2010-2015)
09-16-10 06:11 PM
kqt2ktval
05-15-09 07:10 AM
CK6Speed
09-01-05 10:38 PM
Quick Reply: My Moonroof is stuck on my 2005 RX 330
