Melted Plastic in Rear Boot Opener
#61
#63
Yes, it has happened to me too. The rear hatch rubber is dripping tar onto the bumper. $100 part and $200 to install. Seems to be a problem. Called Lexus -- and out of luck. Does not seem like "Lexus Quality" that we all know and expect. ;-(
#64
Great Deal Guru
http://www.ebay.com/itm/New-Trunk-Ha...lXArg0&vxp=mtr
#67
Received the ebay part today.
The melted rubber was a mess. I couldn't get all the melted goo off the switch.
Installed the new rubber onto the switch and it looked good.
This ebay part is a very cost effective solution to a common problem.
#68
1) Throw cash at it ( this is what most people do)
2) Complain to the wall at Lexus. You will only get madder.
3) Buy a Porsche ( If you can afford it)
That's about it. Jamie
#69
#70
Our 2008 RX350 75xxx miles here in MO is also melted. Switch still works
Haven't bothered to ask dealer yet, but my concern is water getting up and into switch or inside the door itself
Should I be concerned about water?
#71
Annoying problem shouldn't happen on luxury car. Lexus should have pride enough to fix. However, simple solution. Remove two Phillips head screws, cut a piece of silicone sheet 1.5 in. x 4 inches. punch holes to match. Screw silicone sheet to cover the mess of deteriorated rubber. Silicone sheets are $15 from Costco designed as baking sheet liners. So for $15 you get the repair and two sheets left to bake with
#72
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I found out today I got this melted rubber also and I live in Minnesota since I brought it. I don't remember from when the switch start not working, probably two years ago. It didn't die suddenly but after couple times I had to push my finger strongly in order to open it I couldn't do it manually any more. By the way, the remote button on the key still works so I didn't pay much attention to it.
Today when I browse the forum trying to figure out what could be wrong with the power back door, this thread came to my attention. So I checked it and found that the rubber became sticky, very sticky. I then get the screw out and tried to clean the rubber hoping that after cleaning it may start working again. Unfortunately even after I clean the rubber, the switch doesn't work. Does that mean that I have to buy the who assembly and install it?
The mechanism of the switch does not seem to be complex and just act like normal mechanical switch. I could think where it could be wrong.
Does anyone have any idea about how to check it? My concern is there may be some issue somewhere else, not the switch. Remember that the remote for opening the back door does work. Thanks!
#73
To check if the switch is working, you would need to unplug the switch from the car's wiring and use an ohmmeter to test the switch. IIRC, you have to remove the trim panel on the inside of the door to do this. Ditto for if you have to replace the switch. I'm pretty sure someone replaced that switch and posted a how-to with photos.
dcdyd (10-15-17)
#74
DennisMik, thanks for the advice. Next step for me is to get the switch off and test it out. Yes there is a link in this thread for how to take the switch off. By the way, the tailgate opening button on the driver side of the front panel doesn't work unless i used the remote key to open the door. Once I opened the tailgate using the remote, I can use the button to close and open it again. However couple minutes after the tailgate is closed, I can't open it again. Anyone have idea about this?
#75
So are all these rubber covers melting because of engaging the truck release from inside or from the fob's? Wow, seems they only work for split second and just noticed happening to mine after 9 years. Not sure how this happens but constant zapping? Appreciate the insights why?
